Question about Craftsman Garden
I have a rototiller that will only run with choke on. changed sparkplug and fuel. blew out lines with compressor still will not run outside of full choke
  • 760 Answers
If it only runs with the choke on it isn't getting enough fuel. You will probably have to disassemble the carb, and clean well. Engines and carbs vary, but the main fuel passage from either the tank or fuel bowl, just be clean. Sometimes just blowing out won't do. Might be worth buying a carb kit, and clean it throughly. Sears web site will have a great parts breakdown if you enter the model number. See link: www.searspartsdirect.com
Posted on Jul 03, 2010
2007 Kawasaki KX250F only runs with choke on
HI JERRY
HOW IS THE FLOW DOWN FROM THE TANK OR FUEL FILTER
MAY NEED TO CHANGE FUEL FILTER OR CHANGE FUEL LINES OR TANK VALVE BECAUSE USING FULL CHOKE SUCKS THE FUEL AS HARD AS THE BIKE CAN TO GET FUEL THROUGH THE SMALL LINES LET ME KNOW WHAT YOU FIND OR DON'T FIND
May 18, 2018 | 2007 kawasaki KX250F
Earthquake Vector Compact Tiller Model#26750
Did you pull the spark plug and clean it, as well as the plug well and compression ring. Blow it out with canned air and dry before replacing the plug. Be certain the plug GAP is correct and it is free of carbon deposits. Rest the plug, tighten by hand and let her go. See if that fixes the problem.
Feb 27, 2014 | Earthquake Vector Compact Front Tine...
WHATS WRONG WITH TILLER ONLY RUNS ON FULL CHOKE BUT NOT LONG IT HUSQVARNA
There is something clogged in the carburetor. You will need to completely clean it or replace the carburetor.
Dec 04, 2017 | Husqvarna Garden
Only runs on choke
fit a diaphragm kit in the carby
the pump diaphragm is the first to fail and then the float diaphragm distorts and will not let in enough fuel to keep it running
Jan 10, 2018 | Craftsman 25cc Gas Line Trimmer
Husqvarna 142e will not stay running. Going through the sequence of full/half choke it will start and run at high rpm when choked. Even after warmed up, it will die within a few seconds after dropping the...
If it is only running high at full choke - then it is not getting enough fuel.
You've cleaned out the whole thing - so it's not air that's the problem. It's running - so it's not a spark problem - it's a fuel problem.
If you have a fuel filter - change it out or clean it properly. If the fuel line is clear, then you need to adjust the running setting of the carb - there are usually 2 setting knobs -one for idle - one for running / mix.
You need it running richer till you get it going - then trim it back to stop it smoking and get a good rev.
Aug 28, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Lawnmower starts but won't continue to run
if you are getting no fuel to the plug you either have a stuck float, plugged fuel line or filter. does the gas reach the carb bowl? does the mower have a fuel pump? if so the diaphram might be bad.
Jun 30, 2009 | Garden
Mower has to be chocked to run
Oftentimes, this problem is the result of mowers left outside in ambient air that is high humidity. This, in turn, allows algae to grow inside the carb fuel float bowl and/or inside the fuel tank if left out for extended periods (one month or longer). Also the same thing will cause air filters to clog rapidly with mold and mildew - slowly at first, then more rapidly as the mold continues to grow. Get out the carb cleaner in spray cans and go through every ported passagewway in the carb body then reassemble using CLEAN screws, gaskets and all interrior parts. Any residue mold or mildew will continue to grow - and it can grow in gasoline!! Imagine that!!
Jun 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Weedeater XT 85T wont run
Check to see if your feul line is cracked or it is drawing air . Check your clamps that hold the lines on . One other thing you can check is to see if any bolts are loose that hold the carb on . Best of luck Ed.
Jun 18, 2009 | Garden
Garden Logo
361 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
