Simpson ezi set 750 water will not shut off at set level and overflows sometimes
  • 4,070 Answers
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Posted on Jul 03, 2010
My top loader Simpson ezi set washing machine over fills what can I check to get it working normal again
check the small tube to the level pressure switch
check the switch is working
check/replace the water control solenoid / diaphragm
tests are
with out clothes
select a low level wash
listen as the water flows in
when the tub is about 1/2 full the water solenoid shouf make a clunk sound and the water cuts off
at the same time the wash cycle begins
if the water comes right up and there is no solenoid sound then check the small tube or the water level switch
if there is the sound but the water continues replace the diaphragm in the solenoid
Nov 04, 2016 | Simpson Washing Machines
How do I replace the fill level controll valve in a espitit 750
Did you check the tube that comes up from the tub to the pressure switch for the fill level? A lot of the time, the tube is either clogged or has a hole in it
Oct 13, 2014 | Simpson Washing Machines
I have a simpson ezi 750 washing machine that goes out of balance very badly every wash what can I do
First thing to do is to get a level and make sure the washer is level from left to right and from front to back. If it is then you may need to check inside the cabinet to make sure nothing is loose or disconnected.
Mar 22, 2014 | Washing Machines
I have a simpson EZI set 750 went to use this morning turned machine on nothing happened no lights on panel
Hello Barney - sorry about your washing machine and I can only offer you this link to some reviews of the machine. A couple of reviews down the page have links to Simpson representatives, who may be able to help you out with the issue. Take care. Kind regards,
Simpson EZIset 22S750L 22S750M
Mar 18, 2014 | Ariston Technologies AWD 121
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
Feb 09, 2012 | Simpson Esprit 750 Top Load 7.5kg
WashMachine wont wash and wont stop filling
There is a rubber tube that goes from the outside of the outer plastic bowl up to the pressure switch in the top panel. It is on the left rear corner. It may have been pulled off the pressure switch. Look under on that corner and locate where it is attached to the plastic bowl. if that is OK then follow the tube up and check top connection.
Hope this will help you.
Feb 07, 2012 | Simpson Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Simpson eziset 450
It sounds like the drum is so away from level that water is not flowing to the drain line, hence the pump running out of water. I would make sure the machine is level and the drum is resting level if it's the type that pivots around inside the machine. Failing that I would open up the machine and check the hoses to make sure they're not blocked. I would also check the drain hose to make sure it's not placed too high or in a way that will obstruct water flow.
Oct 19, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
