Question about Honda 2500 PSI Gas Pressure Washer
If I find gasoline in the oil reservoir... is that bad? I know it is!!! :) what do I do to fix this problem. Any help would be great. Thanks, Mark
  • 760 Answers
Gasoline in the oil is very bad, but may not be hard to fix. If you run it that way, the engine will not receive proper lubrication, and could even be a fire hazard. If your carb is leaking gas when the engine is off, it will run into engine, and leak down into the cylinder and then past piston rings and end up in the crankcase. This also washes the oil from the cylinder walls, making them dry when you first start the engine. What kind of motor and fuel tank and carb will determine how to fix this. Most equipment I have, I've installed a fuel tank shut off valve if it didn't come with one. Good luck
Posted on Jul 03, 2010
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
Runs rough
The problem of rough running of vehicle may also arise due to following reason other than you mentioned and they are listed below:
1. Bad gasoline condition
2. Clogged Air Filter
3. Poor fuel filter
4. Discharged battery
5. Low oil in reservoir
Check for the components and solve the issues. Cleaning or replacing the air filter and fuel filter can solve the issue. Charge the battery if it is discharged or replace it with new one if in bad condition. Refill the oil reservoir.
Jun 23, 2013 | 1999 Ford Ranger SuperCab
I have a h1 hummer that will not start i have changed the glow plugs and the controler also the box on the injecter pump. I am geting fuel and the glow plugs are working. The hummer has set for a year....
Diesel fuel doesn't go bad like gasoline, at least not as fast. I've been around diesels in construction equipment and sometime a machine will sit for a couple years and still start right up. You have other problems. I don't know that much about the Hummer diesels but, Ford uses a high pressure oil pump to fire the injectors. The main oil pump supplies oil to the high pressure oil pump reservoir and then the high pressure pump supplies oil to the injectors. If Hummer uses a similar system the reservoir may have drained down and there is no oil for the high pressure pump to pump. Ford has plug where a person can fill that reservoir manualy if necessary. Maybe try cranking it some more, don't crank it more than 10-15 seconds at a time. Walk away from it for 10 minutes or so, then try again, make sure you let the glow plugs cycle. If it don't start after a half dozen tries, you may have to have a mechanic look at it. I'm sorry I can't be more help.
Feb 11, 2010 | 2002 Hummer H1
Craftsman SnowBlower
The term "Unleaded gas only" refers to the type of gasoline to be used. You would use "Unleaded gasoline" instead of "Leaded gasoline". Yes, you will mix oil with the gas normally at a ration of 50 to 1. (1 pint of oil to 6 gallons of "Unleaded Gasoline"). If you do not put oil into your gasoline, you will burn your engine up due to lack of oil. I hope this helped, Good Luck Please rate me, Thanks
Dec 25, 2009 | Garden
It was throwing white smoke out of ex now it dont run
In my experience, white smoke is oil burning. Question is Why?
Could you have put too much in the engine? You might have broken rings. You at the very least have fouled plugs now. Clogged crank case vent?
Check the oil level and adjust as appropriate. Rings is a big deal. Plugs are pretty cheap and easy to change.
I hope this helps you solve your trouble.
Thanks for using FixYa.com
Positive comments welcome
a
Oct 26, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Oil leaking out of electric remington saws(pole and regular)
if you jump on the net ,google remington electric chainsaws you will have the info up front---------personaly I think they should have stuck to shavers
Aug 25, 2009 | Remington Electric Chain Saw
Bad Gas?
maybe you should first empty the tanker of the bad gasoline if left
Oct 30, 2008 | 2003 BMW 5 Series
Honda 2500 PSI Gas Pressure Washer Logo
179 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
