Question about Refrigerators
Im not sure which way to turn my knob to make it colder and which way makes it warmer
    Genius:
  • 1,073 Answers
Right colder left warmer
Posted on Apr 17, 2008
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
How do make my mini fridge colder there is a knob from 1- 10 is lower colder or warmer
Hi!
Here's an answer for you:
Setting the fridge knob to 10 will get it to the coldest possible
That means, lower is WARMER
Best regards!
Aug 09, 2011 | Sunbeam Refrigerators
WONDERING WHY MY GE GSS22SGRB SS REFIGERATOR ISN'T GETTING COLD, ALTHOUGH THE FREEZER SEEMS TO BE WORKING PROPERLY.
you should have a dial or knob that says freezer colder or warmer if so turn it for freezer to get warmer thast should allow cold aiur from freezer to enter into ref. that should make ref. colder. if to cold then dail it back a little at a time till ref. is what u like. ok try that. later gator.
Feb 15, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
My sears kenmore fridge # 106.74209401 keeps freezing things in the fridge no matter what temp i set it for..according to this site it might be the air baffle, but cant find it. parts page shows it at the...
ok there should be 2 dials or knobs one on right should say freezer colder and warmer. by making the freezer warmer u r turning the air baffle so more air goes into the ref. and less stays in the freezer.. ok try that.
Feb 13, 2011 | Refrigerators
Lose of coldness in fridge
adust your letter knob in ref. or it could be numbers it will say freezer coldfer or warmer make freezer warmer should make ref. colder. ok
Feb 12, 2011 | Whirlpool Refrigerators
The ge refrig. is 9 years old. Regardless of the refrig. setting, from 5 down to one it is too cold. set on 3, after 24 hours it is 28 degrees in the crisper and 32 degrees in the main refrig. tried...
ok u ok u turning wrong knob..turn other knob the one with the letters. make the freezer colder than u make ref. warmer. that knob controls a flap that controls how much cold air flows from the freezer to ref. ok
Feb 12, 2011 | GE Refrigerators
How to make my freezer colder
Hi, some thermostat control knobs and directions to make it colder are different. Here is the best way to find out which way to turn it to make it colder. Make sure you hear it running. Take the control knob and listen carefully while you start to turn it in one direction first. Turn it until you hear the unit shut off. If you turn it all the way to the left and it keeps running, turn it all the way to the right until it stops running. Once you know which way it stops running when you turn it, this will tell you that you need to turn it until it comes back on again and runs. This will be the way it turns to get the temperature to get to a colder setting. When you are doing this, do it very slow and give it about 3 minutes in between each time you start to turn it the other way. On mine it has numbers on it. The higher the number lets say from 1 to 8, the colder it gets, but some are the lower the number the colder it gets. So, you want it to shut off, so wait until you hear it running before you turn the knob. You can open the doors and it will make it come on faster. So when it goes off when you turn the control knob, you will no to turn it the other way for it to come on and it will get colder the more you turn it in that direction. Very easy. PS If it doesn't get colder when you find out which way it goes, you may have a bad thermostat. Please let me know. You can put a thermometer inside to watch the temperature
Good Luck,
Shastalaker7
Jun 30, 2010 | Hoover 9.9 cu. ft. / 280 liter Upright...
Airconditioner turns on and off automatically.
It is normal for an air conditioner to turn off and on automatically. This keeps it from making the room too cold. If it has a digital thermostat, set the thermostat to what temperature you want it to be in the room. If the air conditioner has a knob that says "colder", you let the air conditioner run until the room is comfortable to you and then you turn the knob very slowly toward warmer until the air conditioner turns off, and then very slowly turn it back to colder until the compressor comes back on. It's normal for a non-central air conditioner to run the entire time you have the power turned on but the compressor, which provides the cooling, will turn on and off when only when cooling is needed.
Sep 20, 2009 | Samsung AW0603B Air Conditioner
Eaton viking fridge needs to be colder
when you turn the knob anticlocwise it will be warmer and clockwise will be colder. some thermostat switches when you turn it anticlockwise untin it clicks turns off your fridge completely.
Sep 06, 2009 | Refrigerators
Refrigerators Logo
188 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
