Question about KitchenAid KBMC140HSS Convection/Microwave Oven
KitchenAid Convection Fan Problem
After using the self cleaning feature on my KitchenAid oven, the convection fan made a popping noise and started smoking. I replaced the fan, but it still does not work. The oven works fine except for the convection features. I also replaced the door lock switch because it was damaged during the self clean cycle.
    Brigadier General:
  • 3,917 Answers
Hi
Please check the links bellow to have an idea to your query which will help you to diagnose your problem….
http://www.fixitclub.com/Major_Appliances/Convection_Oven.shtml?page=1
http://www.ehow.com/how_2067299_fix-convection-oven.html
http://www.dacor.com/Customer-Care/FAQ/Convection-Oven-Buying-Tips-and-FAQ/Index.aspx
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 03, 2010
Why does my GE Spacesaver Profile, Microwave/Convection Oven, model # JVM1490SD003, in my motorhome, make a clicking noise when I start it up? Sounds like a fan hitting something. The noise goes away
Probably is the fan tapping something. Power it down/DISCONNECT power. pull unit and if there is a cover, remove it. look for the convection fan and see if it free-spins. should find spot where it is hitting and could be adjusted.
Nov 22, 2014 | GE Microwave Ovens
My Kitchenaid combo convection/mw works on convect but has a loud humming and no heat on microwave.
A loud humming noise in microwave mode will usually be a shorted high voltage diode or bad magnetron.
Sep 16, 2013 | KitchenAid Architect II KHHC2090S ...
Microwave exaust fan starts on its own
There's a humidity sensor in this microwave oven that turns on the fan automatically if it senses an excess amount of humidity (steam from cooking for example) to possibly protect humidity or moisture from building up inside the unit.
Apr 01, 2010 | KitchenAid KHHS179LSS Convection /...
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
I've a Sharp R-953. convection+ microwave makes a lot of noise
check the fan blade on convection, may be loose.
Oct 30, 2009 | Sharp Microwave Ovens
Will an over the range microwave exhaust fan start automatically If the range cook top gets too hot.
NOT THAT I'M AWARE OF . YOUR UNIT SHOULD HAVE A SWITCH TO TURN ON AND MUST BE TURNED ON MANUALLY
Oct 12, 2009 | KitchenAid KHHS179L Convection/Microwave...
Clicking noise of fan on convection
The motor on the fan has to be replaced.The fan is hitting the screen .Hopfully that will fix it .Thank you .
Nov 05, 2008 | Sharp R-1850A Convection/Microwave Oven
Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Oct 25, 2008 | KitchenAid KEMC377K Convection / Microwave...
KitchenAid KBMC140HSS Convection/Microwave Oven Logo
144 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
