Question about Mitsubishi WS-65313 65" Rear Projection HDTV
I have a ws65313 mitsubishi, when i go to turn it on the green light next to power button turns on and i here a few clicks coming from behind tv and green light turns off. no picture or anything during that time. Would appreciate ur help.
  • 10,594 Answers
It sounds main power supply of tv is not working, you hear clicks of relay that clicks to turn On main power supply but it wont turn On due to some thing wrong there.
Most probably smps output chip got bad along with few supporting parts. Visual check of technician is needed to fix the issue.
Local tv repair shop will help you to get it fixed under $150 or so.
Thanks.
Posted on Jul 03, 2010
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
Sep 03, 2014 | Mitsubishi XD221U New
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi medallion hd 1080
I would try the reset button in the front. Unplug the set push the reset and plug it back in.
Mar 27, 2014 | Televison & Video
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi tv model wd-62531 less than 2 years old
It sounds to me like your bulb has burned out. Look behind your TV for where the bulb housing is and pull the bulb out to check if it's burned out or not. You'll know when you look at it if it's toast.
Dec 10, 2008 | Mitsubishi WD-62531 Projection Television
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
156 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
