Question about Daewoo DTQ-13P2FC 13" TV
My boys locked my sharp color tv receiver model 21mf2-A mks how do i access the pass word to open it
Forgot the password to my Sharp television.. Model number 21MF2-Amk2.. Need help resetting it..
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 29, 2016 | Computers & Internet
How do I adjust the vhold on the sharp 32u-s80? My screen is flipping
[PDF]32US60 Operation Manual - Sharp Electronics
files.sharpusa.com/Downloads/.../tel_man_32US60.pdf
Sharp SolarEvery SHARP Color Television set is tuned and adjusted for proper color and ... serious injury to a child or an adult, and serious damage to the equipment.
SHARP 54GS-61S OPERATION MANUAL Pdf Download.
www.manualslib.com > Brands > Sharp Manuals > CRT TV > 54GS-61S
Sharp operation manual color television 32u-s50b (48 pages) .... view the all functions implemented in your TV set demonstration and set the CHILD LOCK. 1.
SHARP 32JF-77H OPERATION MANUAL Pdf Download.
www.manualslib.com > Brands > Sharp Manuals > TV > 32JF-77H
Dec 21, 2015 | Sharp Televison & Video
I need a response for my tv sharp 21Mf2-Amk2
Doesn't open? It won't power ON; you mean? Provide more details; please. If it does not power on; fault is with its main power supply regulator [SMPS] section circuit. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 03, 2014 | Televison & Video
What is password for Sharp tv 21Mf2-Amk2 ask
Finding the Manual   Go to the Sharp website, look it up and download it. It should be there.
My sharp aquos tv screen color gone and the colour settings is blocked and cant be used..what will I do to return its tv screen color
If the adjustments you need are blocked out either it is that something that is connected to the set for signal (cable box, sat box, receiver etc) is now in control or in some fashion you have locked out the option yourself--I would have a good look at the owner manual first and if that fails call sharp with the model number----if you recently hooked something new up to the set or moved set from one location to another it may have happened then.
May 19, 2012 | Sharp AQUOS LC-32D44U 32 in. LCD TV
How to reset pin code for matsui tv model 28wn05
I need to know how to unblock my tv Sharp 21mf2 amk2
May 06, 2010 | Televison & Video
My vizio hdtv color is off and i need help adjusting it
We had the same problem (for about a week) and finallly realized that the kids had played with the cords in the back of the TV and one connection was loose.
Mar 26, 2009 | Vizio VW32L 32 in. LCD HDTV
I have two Sharp Flat Screen TV model # LC-26SB14U. One is hooked up to a regular Dish Network HD receiver. The other is hooked up to a HD DVR receiver. Both are hooked up to the same Phillips DVD player....
if you using the component input on both tvs I will check the settings on the receivers, "HD setup", the difference is because the settings are set one on 480i and the other on 1080i
Dec 02, 2008 | Sharp Televison & Video
Accessing Menu Sharp TV
its very easy on the t.v and press on channel up or down on your tv. u will get the screen
Aug 25, 2007 | Sharp 25L-S100 25" TV
Daewoo DTQ-13P2FC 13" TV Logo
50 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
