Question about HP Compaq nc6000 Notebook
Is it time to replace my fan?
I have a previously owned nc6000. The fan was always loud. But now I can barely hear it. Is that a good thing or a bad thing? Should I replace my fan or clean it with canned air?
Yes I do use my laptop on my bed :(
  • Janeen Jackson Apr 17, 2008
    I m sorry...I can't quite understand what you are saying. Are you saying brush the fan off?
    BTW Thanks for answering my question!
  • 63 Answers
Its not good to you cmputer..
the fan to loub can infecteted another hardwre..
you can cleanup by brush...
Posted on Apr 17, 2008
How fix Loud g4 Hard Drives
Not sure what you mean by loud Hard Drives. Hard drives are so quiet you can barely hear them. If they are loud the only cure is replacement. However, I have never heard a hard drive that I would consider 'loud' in all my years in computing./ As you show a mirror fronted mac in your question - I think you may mean loud 'Fans'. This mac was notorious for its loud fans. They can be replaced, but I seem to remember a firmware fix from Apple to slow them down - or it may have been a 3rd party utility.
Apr 01, 2012 | Apple Power Mac G4 Desktop
Whats with the front fan noise? I purchased a refurbished machine that is really loud! Sent it back for replacement of the unit; instead the fan was replaced(I GUESS) and when returned, its still very...
I have one of these and must say the fan noise is barely noticable, are they using a genuine fan? the original is speed controlled whereas a universal replacement would just run at full speed all the time.
Hope this helps
Dec 02, 2010 | HP Compaq dc7100 PC Desktop
Driving down the road a loud humming noise is present. when slighlty turning the steering wheel the noise quit. could it be the hub assembley? I have a 2002 durango .
I don't thing so, listen carefully the next time you are driving and see if you can hear what side it is on, If you identify a side the most lightly problem would be the wheel baring (runs through the centre of the hub). If it is the bearing, it will get progressivley worse and will need to be replaced. Good luck!
Aug 11, 2010 | 2002 Dodge Durango
NC6000 starts to boot but then turns off, no lights or screen. I can hear the fan when the power is turned on?
On ac adapter and battery power,could be several things sounds like bad caps on the main board. Less expensive to replace the motherboard.
try here
Oct 07, 2009 | HP Compaq nc6000 Notebook
Try pressing Fn+F8 (or the Function key with LCD/CRT) it toggles through 3 or 4 options so you may have to press more than once
Oct 04, 2009 | HP Compaq NC6000 Business Notebook
I have tinnitus and I can barely hear the person who called.
The ear piece is out of order.Just replace it u'll be satisfied.
Sep 23, 2009 | Cell Phones
Loud Noise
IT will give the noise because of the following reasons
  • Due to signal distortion and also that you mieght be useing faulty bluethooth head set .
  • It also occur due to low bettry chargeing
Things to do !
  1. check your blue tooth head set with other Motorola cells
  2. replace your blue tooth head set
  3. clean the connector of the blue tooth cable
Please Rate !
Sep 05, 2009 | Motorola Mobility Motopure H12 Bluetooth...
My cpu fan will not shut off it is so loud should i replace the fan or is there a way to repair this problem
Your CPU fan should always be on while the computer is on. If it's off, your computer is going to crach in a matter of time. The noise is normal. If it's to loud, replace the fan. Nothing major. But it is normal for the fan to be loud. Thats a good sign it's cooling the CPU. But you can get a shfter 1. Your computer might over heat though. Good luck.
Mar 05, 2009 | eMachines T5048 PC Desktop
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
HP Compaq nc6000 Notebook Logo
103 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
