Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
I can't find the battery. Where is it physically located?"
    President:
  • 3,085 Answers
It is on the top edge of the black panel, next to the blue slider, pull up and out
Posted on Jul 03, 2010
Actual battery type & Physical location of cmos battery
I don't know about that particular model but it is normally under the keyboard near the touchpad
Oct 19, 2013 | NEC Versa SX VS4E0 PC Notebook
Where is the fuse panel located on a 1994 Oldsmobile Cutlass Sierra?
Most of the fuses are in the fuse block but I don't know the physical location. The fusible links associated with the battery are in-line types. The fuel pump and multifunction alarm have in-line fuses
Nov 13, 2012 | 1994 Oldsmobile Cutlass Supreme
ULT31502 battery replacement
Battery replacement is simple. Getting the right battery is going to be the challenge. Original batteries, as there are two of them in my Ultra 1000va UPS. Replacement batteries need to be searched for. You must accurately measure the physical size of them for Height, Length and Width. There is not a lot of extra room, so look for ones that are higher capacity amp/hour wise but still the same physical size. Pay attention to the position of the battery terminals when looking at the specifications. Also you will need to know which type the spade terminals are and measuring their width will assist you in getting the correct type. I searched a lot of sites before finding what I needed and then shopped e-Bay for a good deal on two of them that was slightly larger capacity yet still the same physical size, terminal size the same between two available types, and they worked great. Original batteries were both split open, but the gel cell type saved me any damage as nothing leaked out. Easy to remove as there is just a mount plate that needed to be removed by removing a screw or two as I recall. Physical size is the key to an easy installation in the limited space in which they lay on their side. Pay attention to the location of the positive and negative on each of the two batteries as they were connected in series! Draw a diagram and label each of the terminals on each battery before disconnecting them. Be patient on the search and the time it takes to check the dimension of the battery for each battery you click onto and you will be OK with getting a suitable replacement!
Jul 02, 2012 | Ultra (ULT31502) UPS System
On a battery for a 1994 BMW 530 Touring, where are the negative and positive poles located when battery is in place, under the rear seat?
Golden rule with batterys..
The Positive terminal is ALWAYS physically larger that the Negative.(ie larger battery post ) The Negative will be the EARTH connection ( bolted to car body and engine) There may be hard to see (-) or (+) on battery leads . Colours do not matter either as manufacturers vary on this !
Good Luck
Oct 09, 2010 | 2002 BMW 5 Series
Where is Rectifier physically located on Sabre 2003 VT1100C2
Trace the neutral/ground battery cable to the "fuse box". There is a harness that runs from there to the rectifier/regulator.
Mar 22, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
How do i change the battery
First you need the proper replacement battery. Be sure it will physically fit, and the + and - posts are in the same location as the original.
Remove the - (black) cable first, then the + (red). Undo the battery hold down and remove the old battery. Place new battery in tray, install hold down hardware. Check battery cable connectors to be sure they are clean. Use a wire brush or battery terminal cleaner brush (any auto parts store, a few bucks) to clean off any corrosion. Connect + (red) battery cable, then - (black) cable. Tighten cable clamps.
Feb 06, 2010 | 2006 Nissan Xterra
My charge port is messed up and wont let me charge
You could locate another specifically for charging the battery in this one, but the best bet is to see your carrier about insurance (physical damage) if you have it or warranty replacement (no physical/liquid damage). Sometimes the manufacturer can offer warranty repair services as well.
Aug 08, 2009 | LG enV VX9900 Cellular Phone
Starter
Generally located at the bottom of the engine, one end actually mounts inside of the engine itself. Physical location varies somewhat with the engines that are available on the Trailblaizer. When all else fails, follow the positice cable from the battery to the base of the engine. The positive cable connects to the starter. Remove the negative terminal on the battery before you touch any of the electrical conncetions since the engine and all other metal parts are grounded to the negative side of the battery.
Jun 01, 2009 | 2002 Chevrolet TrailBlazer
Starter has gone out, just clicks when you turn it over. Need to remove but can't physically find it without removing multiple covers. Need help locating and any tips are appreciated
This might sound silly, but if it's clicking, that can mean it just doesn't have enough juice. Are you sure your battery is charged up? It's worth checking. Usually a "dead" starter will make a lot of noise, either grinding (worn out teeth) or whirring (not connecting with the flywheel). Just thought I'd mention it....could be the starter but worth checking the battery too.
May 23, 2009 | 2006 Kia Sorento
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
42 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
