Question about Proscan 40LD45Q TV
When I Turn Proscan TV on it automatically turns off (just turns on for less than a second)?
  • 11,361 Answers
You may have power supply DC filter caps problem, that will be the first place to look.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 03, 2010
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
I try to turn my proscan tv on and the the power comes on but before anything the tv blinks a d it turns off immediately, any advice?
About 51,900 results (0.55 seconds) Search Results
    My Proscan 42 tv is turning on and off by itself, changing ...
    www.shopyourway.com > Manage My Life > Questions
    Oct 16, 2012 - My Proscan 42 tv is turning on and off by itself, changing channels on it's ... that is next to the power connection plug is discolored at the board.
    Proscan/RCA 123882 Power Supply Unit (PSU) Boards ...
    ? 2:48
    https://www.youtube.com/watch?v=TC908vQ8jaw
    Jan 17, 2013 - Uploaded by ShopJimmy.com
    RCA TV Repair for Blank Screen TV Will Not Power On How to fix... I have a Proscan PLDED3273A-E. Looks like my problem is the L1 (brown spot on board) - any suggestions? ... before it turns off the audio still works and the image still comes out if I ...Recently I tried turning it on and I get no standby light.
Jan 25, 2016 | Proscan Televison & Video
When i turn proscan tv on it automatically turns off(just turn on for less than secon
OK I Have a 40" Proscan 40LD45Q
had the power problem when you turn it on it would flash and then cut off again.
after checking I found that the transistor on the power board was bad.
Its one of the 2N4401 transistors found on the cold side in between the
cluster of resistors and and mosfet heat sink. kind of hard to get too
but replaced it and tv works great now.. $1.19 at radio shack for the part.
Hope this Helps ..
By Lynn
Feb 22, 2012 | Proscan 40LD45Q TV
When my ps3 is hooked up to my proscan lcd 37LC30S60 via hdmi it has a blank screen that says no support
Have you tried changing the settings on the ps3? If you go into the display settings adjust them Also if you want to change the ps3 to the default
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn the system off.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • Hope this helps.
    Thank you,
    Lee
    Dec 12, 2009 | Proscan 37LC30S60 TV
    The screen turns on hen off
    Just try to reset;
    Resetting the TV
    Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
    1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
    2. Unplug any connected devices (DVD, Set-top boxes, etc...)
    3. Press and hold the TV power button for five seconds.
    4. Plug the TV power cord back into the power outlet and turn on the TV.
    5. Open the on-screen menu to confirm that the TV is responding again.
    6. Turn off the TV and reconnect the devices.
    7. Turn on the TV.
    hope this may help;
    Regards,
    VOTIT
    Sep 14, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
    Proscan PS52682 - Turns on then quickly goes off
    sounds like a control pannel problem further trouble shooting
    Aug 14, 2008 | Proscan PS52690 52" Rear Projection...
    Proscan tv 36in
    Many problems with this unit with the HV transformer (flyback) and also a regulator ic in the power supply. Sorry, nothing easy for this type of problem. You will need a tech to diag. and repair this problem.
    Mar 01, 2008 | Proscan PS35660 TV
    Lcd 32" proscan need code for universal remote
    Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
    Oct 19, 2007 | Proscan 32LA30Q Television
    Proscan 40LD45Q TV Logo
    696 people viewed this question
    Top Proscan Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Jaime Hernandez
    Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
