Question about JVC KD-PDR30 Car CD/ MP3 Player
No audio from clarion dxz 788rusb aux mode,when
No audio from clarion dxz 788rusb aux modewhen external device connected.by mistake my aux  code touched with power (12 v) in my car
How do i get my clarion vz401 too play dvd videos from my USB
The Clarion VZ401 can only play audio (MP3 or WMA) files from a USB device. This is listed in the manual on both page 33 (USB Operations) and page 46 (Specifications). This unit can't play audio file with DRM and some USB drives may not be compatible with the device. It can play some videos from some IPod/IPhone models with the Clarion CCA-750 adapter. This is a USB to RCA composite stereo audio/video jacks cable. This feature isn't compatible with the Lightning connector or some versions of the iOS operating system. To view any other videos, you need to play them back on a device that can directly connect to the composite RCA audio/video ports (AUX In or AV In).
I hope this helps. The list of compatible IPod and IPhone models is available from Crutchfield on the VZ401 Details tab: http://www.crutchfield.com/S-ix4f1cAUkb9/p_020VZ401/Clarion-VZ401.html . This tab also has a link to the manual; the direct link is http://d2stobyut4u5rx.cloudfront.net/ImageBank/v20150407084800/Manuals/020/020VZ401.PDF .
Nov 18, 2015 | Clarion Car Audio & Video
Samsung ht-c653w will not give me any sound at all from my digital audio in or my a/v input. (trying to hook up my ps3) But when I hook up the hdmi, the audio is fine for any dvds I play. think it's...
Have you selected the AUX IN?
AUX2 : Connecting an External Analog Component
Analog signal components such as a VCR.
Connect AUX IN 2 (Audio) on the back of the product to the Audio Out of the external Analog component.
Be sure to match the colors of the connecting jacks.
Press the FUNCTION button to select AUX 2 input.
The mode switches as follows :
DVD/CD ? D.IN ? AUX 1 ? AUX 2 ? USB ? IPOD ? FM.
Jun 05, 2011 | Audio Players & Recorders
Whatever I listen to, the sound comes out of my tv instead of my speakers, although when i checked the speaker volume there working
Free PDF Instruction Manual at the link below.
http://download.p4c.philips.com/files/h/hts3154_05/hts3154_05_dfu_eng.pdf
Check Page 10 Point 2.
b Source buttons
- DISC/USB: toggles between DISC or
USB mode.
RADIO: toggles between FM and AM/
MW band.
TV: switches to TV mode. The sound
from the TV will output through the
connected speaker system.
AUX/DI: switches to the external device
that is connected to the AUDIO IN-AUX
socket.
MP3 LINE-IN: switches to audio device
that is connected to the MP3 LINE-IN
socket.
Apr 17, 2011 | Philips HTS 3154 Theater System
How do I turn my jvc kd-g200 to aux mode?
Thi JVC KD-G200 does not have an auxiliary input, or aux mode. If you want to play audio from an external device through this unit, you will need a FM transceiver.
Mar 03, 2011 | JVC KD-G200 CD Player
I am installing this clarion dxz435 i need the wiring diagram to know what wise does what
Your local Clarion dealer can provide that for you. They have a dealer located at Clarion.com
Dec 05, 2010 | Clarion Sirius DXZ-435 CD Player
I CANT SET THE TIME ON MY CLARION DXZ525 CD PLAYER IN MY CAR
press and hold the "am" button for a couple seconds. press the forward button next to volume knob until it says clock. rotate volume to change time(there is am pm) and press forward again to change between hour and minute. press the play/pause button to "save" changes. hit the am button to return to the correct time :D
hope that helps
Oct 26, 2010 | Clarion DXZ-525 CD Player
CD is stuck in player clarion 525 and is not coming out what should I do ?
PULL OUT THE RADIO FROM THE CAR WITH THE SCREWDRIVER REMOVE THE SCREWS THE ONES THAT ARE IN THE CORNER UPER AND REMOVE THE COVER FROM THE RADIO AND JUST PUSH THE CD TO THEW OUT SIDE (DONT TOUCH THE LASER BEAM) AND COVER THE RADIO AND REINTAL THAT SHOULD WORK
Feb 10, 2010 | Clarion DXZ-525 CD Player
I cannot figure out how to change my aux settings to on. Nor the d-aux. any help? I am also unable to change the display color.
try this
Setting the AUX Mode (V-Link)
AUX IN ON / AUX IN OFF (Initial setting)
You can input TV/video sound by connecting an optional Ai-NET/
RCA Interface cable (KCA-121B) or Versatile Link Terminal (KCA-
410C) to this component.
You can change the AUX name display when AUX ON is set. Select
the AUX name by pressing g or f. Then press BAND.
If the KCA-410C is connected, it is possible to select two AUX
names.
• Via KCA-410C, up to 2 external devices with RCA output can be
connected. In this case, press SOURCE/POWER to select AUX
mode and then press BAND to select your desired device.
Jan 28, 2010 | Alpine CDA-9847 CD Player
JVC KD-PDR30 Car CD/ MP3 Player Logo
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
