Question about Campbell Hausfeld 1/2" Impact Wrench - PL2556
Will not remove lug from autos.Motor spins nothing else is happening Ibought the TL 100200RB
  • 760 Answers
An impact wrench has "hammers" that strike an anvil. If you have not been lubricating your impact at times, or if you have a large amout of condensation in your air (water) then it could be rusted. The motor will still spin, but you don't get any "impact" action. Try putting some light air too oil in the air line and if there is a plug for oil, fill it also. Allow to soak and try it again. If it is that bad you might have to dis-assemble, and clean throughly
Posted on Jul 03, 2010
How to test syarter motor using battery only outside of vehicle
our school in 1964 this was covered. Old school.
we now just hot wire it on car, and bam the answer ,ask.?
first is torque reaction, get the starter held down or it will want to walk away, and ? danger can happen. (picture shorting battery and acid flying to eyes)
1: starter held FAST.
2 then connect jumper cable Plus RED to out side large, solenoid lug. and battery , +
3 connect jumper cable black to battery neg lug.then other end to starter casing (mount)
4: jumper the outside lug to the dinky lug, the solenod engages
the pinon flies out and the starter pinion spins fast.
when done remove battery minus lug first.
end.
in the olden days, we fixed bad starters.
and this test , finished that job.
new brushes, and or solenoid and bam.
i just did this on a 68 bug last week.
Jun 27, 2014 | 1994 Geo Metro
Lug nut issues
Your factory custom wheels are designed to use a specific lug nut, most of these lugnuts today include a built in washer that contacts the wheel surface. Your maintenance of re-torqueing the lugnuts after 100 miles following wheel removal is exceptional, and textbook...(some wheel manufacturers recommend this after 50 miles:) I am a long time wheel person through many years of performance wheel applications. My guess would be that a previous owner had installed custom wheels, and removed them at time of selling your Santa Fe...they mistakenly left the aftermarket lug nuts on your car...and these lug nuts do not contact your wheel where they should be to remain tightened...Don't buy new lug nuts unless you can test this possibility first...All salvage yards would have inventory of factory wheels and lugnuts...Also shop on line...confirm the size of your wheel studs...ie 12 mm rht..."right hand thread" and search for someone selling factory wheels...many auto parts stores will confirm your wheel stud thread size any offer replacement sets too. Hope this helps.
Jan 17, 2014 | Hyundai Cars & Trucks
How to remove front wheels of Acura 1996 3.2 TL
The large nut you see is most likely the axle retention nut.
It is NOT used to hold on the wheel.
The wheels on a 2000 Acura TL are secured to the wheel hub by 5 lug nuts.
If after removing the "lugs" the tire and wheel may be difficult to remove after a long period due to corrosion betweem the wheel and hub.
If this happens, tap the tire at opposite ends (like 12 and 6 o'clock) with a rubber or plastic mallet.
This should help to loosen the wheel so you can remove it.
Apr 15, 2013 | 2000 Acura TL
My washer stop spinning. I think it was overloaded; but I removed most of the clothes but it still does not spin. I unplugged it and replugged it; nothing happened. I centered the basket; nothing happened
You need to check the power from the controller to the motor, if there is no power then the controller drive has failed due to overload current driving the motor .
If there is power then the motor is a suspect.
Jul 26, 2012 | Whirlpool WTW5300SQ Top Load Washer
I have a flat tire, but do not have the special tool to take off the bolt. Any ideas? 2010 Honda CRV
Most auto parts stores have Locking Lug Nut removal tools. If you know the size of your lug nut you may be able to buy a single tool that fits on a standard ratchet to remove the locking lug nut. If your lug nut is the type that spins without the proper tool to remove it, your best bet is a mechanic with the proper equipment to avoid doing damage to the wheel or stud.
Jul 05, 2011 | 2004 Honda CR-V
My hard drive wont read it worked before dont know why
A disk-drive has several major components:
* the electronics circuit-board
* the power/data external connectors
* the motor that spins the disk-drive
* the read/write mechanism that moves above the recording surface
* the recording surfaces
No power means no "spin", and nothing happens.
Dead motor means no "spin", and nothing happens.
Dead electronics on the circuit-board means that nothing happens.
Damaged read/write mechanism.
Damaged recording surfaces.
Feb 26, 2011 | Hitachi Computers & Internet
Pump not working
The pump motor is inline with the outlet pipe and can be checked by a)Looking to see if it the motor spins while in the pump out mode. b) Test with AC voltmeter across the 2 terminals for voltage while in pump out mode.
The motor can be removed by removing the 2 hose clips and disconnecting the electrical push on lugs.
If voltage is across the terminals and motor does not spin...indicates that the motor is open circuit and must be replaced.
Jan 22, 2010 | Tecnik 18 in. TKD7000 Built-in Dishwasher
Water not emptying after wash
The pump out motor is inline with the outlet pipe and can be checked by a)Looking to see if it the motor spins while in the pump out mode. b) Test with AC voltmeter across the 2 terminals for voltage while in pump out mode.
Make sure outlet pipe is not blocked or obstructed.
Jan 21, 2010 | Dishwashers
My dishwasher will not drain. When I try to run it through the drain cycle by hitting drain/cancel button it makes one click and nothing happens. I checked for blockages in the drain line and valve but...
Check to determine if the pump out motor is functional by checking if supply voltage is across the 2 terminals in pump out mode with a AC voltage meter. If voltage is present and motor does not spin this is an indication that the motor is open circuit and needs to be replaced. Also check that the outlet pipe is not blocked.
The motor can be removed by disconnecting the 2 hose clamps and the electrical push on lugs.
Can not remove lug nut caps 2003 x -type jaguar
I have an 04 xj8. the lug nuts are a good bad example of half baked engineering. the lug nuts are fabricated from ugly steel with an 11/16 hex end. to beautify this, Jaguar overlays the nut end with a stainless steel 3/4 inch cap, crimped to the nut. On top of this, the nut is to be torqued to 90+ ft-lb! The only way to remove the lug nut without damage is with a SIX POINT socket and a breaker bar or an impact wrench. Using a 12 point socket will deform the cap, causing the wrench to spin on the cap and or the cap to spin on the nut itself. If that has happened, it is possible to recover using a 15 oz or thereabouts ball peen hammer and a deep 3/4 inch impact socket (the black ones). Line up the socket to the cap, doing a best guess to where the flats are and give the socket a light blow. Keep trying that until the socket seems to stick on, then hit it harder. Eventually you will find the right point and the socket will go on and reform the cap. Then a breaker bar can remove the cap/nut. New assemblies can be had for about $6 from "partsbin" or "autohausaz".
Apr 11, 2009 | 2003 Jaguar X-Type
Campbell Hausfeld 1/2" Impact Wrench - PL2556 Logo
223 people viewed this question
Top Campbell Hausfeld Tools & Hardware - Others Experts
John Trevino
Are you a Campbell Hausfeld Tool and Hardware - Other Expert? Answer questions, earn points and help others
