Question about Tappan Kitchen Range
I have a tappan gas stove (model # 30-3457-66) that is
I have a tappan gas stove (model # 30-3457-66/ series # 07100-20151002) that is at least 20 years old. It works like a charm but the stove top and bottom broiler door need to be replaced. I had them professionaly painted, but they only looked good for a short time. Is it possible to find a stove top and broiler door to fit this older model tappan stove? I don't want to replace the stove. Thanks for any help you can provide.
Click on this link below and you can order the parts you need for your Tappan gas stove
http://www.partselect.com/Entry.aspx?Source=GAWS&Brand=Tappan&Appliance=Range&Term=tappan+range+parts&gclid=CMDsiZ6TzqICFQdkgwod-CXJwA
Posted on Jul 03, 2010
  • mawarnusz Jul 03, 2010
    I have already looked at this website, but my model number is not listed.
Hi, I own a Tappan oven..model #TGF364ASF..the
Hi an welcome to FixYa. I am Kelly.
If nothing lights... i.e burner or oven there are only 2 things that can cause this problem. A failed ignition module or a wiring problem. The wiring problem can be a simple short or a broken power lead. All of the stove top ignitors are in a series parallel connection and if one of the burmer control shorts you loose the stove top. With nothing is lighting oven and burners it sure points toward the ignition module or power to the module.
Thanks for using FixYa.
Kelly
Note... The ignition module itself is not cheap.
Apr 09, 2010 | Tappan TGF364AS Gas Kitchen Range
Gas oven not heating up.It will only warm to 150 degree's. It is a Tappan gas range/stove 110 series.
The problem is usually the ignitor not reaching the correct amp draw .When the ignitor does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The ignitor is inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available.
Apr 07, 2010 | Tappan Ovens
TAPPAN MODEL 3 TGF367CFSA, GETTING A F3 CODE, OVEN DOES NOT WORK
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
Feb 07, 2010 | Tappan TGF364AS Gas Kitchen Range
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Sep 07, 2009 | Tappan TGF363 Gas Kitchen Range
Smell gas no heat
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
Aug 29, 2008 | Tappan TGF320 Gas Kitchen Range
THE STYAINLESS STEEL COOKTOP
I NEED TO REPLACE MY STAINLESS STEEL 5 BURNER WITH GRIDDLE COOKTOP ON MY 36 I TAPPAN RANNGE BUT DONT KNOW WHERE TO FIND ONE. I CANT SEEM TO FIND THE SRIAL NUMBER/MODEL NUMBER ON THE STOVE. HELP! DAN WILLIAMS
Jun 16, 2008 | Tappan MGF500PBW Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan  Kitchen Range Logo
221 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
