Reprogram airwell remote to show deg c and other functions
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
To change into degrees Celsius, open battery cover and you will find four dip switches. They are numbered one to four. You will need to switch number three off and then reset the controller. Reset if performed by holding the "SET" "CLEAR" "HOUR UP" and "HOUR DOWN" buttons until the display clears. The remote should now be in degrees Celsius. Below is a part of the manual that I have regarding dip switches:
SW1, SW2-Selection of Reverse Cycle or Cooling Only ModelSW3-Selection of degrees Celsius or degrees Fahrenheit SW4- Selection of time displayed in 12hr or 24hr format.
Hope this helps
I take the time to help, so please rate me
Posted on Jul 03, 2010
Testimonial: "thank you for the prompt reply we cannot get the manuals for these a/cons in Australia any more very happy chappy"
  • mick Sep 03, 2012
    Thankyou for your post very helpfull.
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
Helo i need code for uniwesal remote control airwel
Here are the code of your GE Remote that you can try:
  • GE Codes: 000/ 003/ 004/ 009/ 022/ 031/ 044/ 052/ 054/ 055/ 087/ 092/ 103/ 107/ 125/ 164/ 181
  • Apr 14, 2011 | Universal Remote Control GE174Universal...
    My HP-12B calculator is in grad mode I need to be in deg, how do I change ?
    Is there a button marked DEG->? That is the standard calculator button used to change mode. It could possibly be the shift function of another button.
    Mar 05, 2011 | HP Office Equipment & Supplies
    I have a Vermont Casting (Honeywell) remote with 6 buttons. Ireplaced the batteries from the summer and it does not function. the Room Temp shows, the off signal shows and when you press the on button...
    It's unlikely that you need a new remote. It simply needs to be reprogrammed with the correct code again. Remotes can "forget" the programmed codes if the batteries run down completely or if the new batteries aren't inserted quickly enough.
    Reprogram the codes and it should work.
    Please post back if you need further assistance.
    Regards,
    BElectric
    Dec 07, 2010 | Honeywell Televison & Video
    We have just purchased a universal remote for our ducted airwell air con - we need a code for it and airwell isnt listed on the remote
    I am sorry if ask wha may seem like a few silly questions, but I need some clarification to assist you better.
    -Is this a Residential AC Unit?
    -If it is a residential AC unit, where is the thermostat located for this unit?
    -Do you know if there is a wall mounted thermistor located on the wall in another room or in the room it cools?
    I ask these questions, because generally if the fan coil is mounted in the ductwork, then there isn't always a way of controlling it remotely. Generally, it's controlled by hard-wired thermostat.
    If you know it was controlled remotely, then you will need to go the website for the Airwell Fan coil and do a search on programming the remote. I'm sorry there is no short cut for this, you will need to obtain the code from Airwell.
    Hope this helped... :D
    Jun 27, 2010 | Heating & Cooling
    Airwell Spilt Level system does not respond to use of remote and can only be operated by manually switching on and off.
    When you press a button on the RC, does a arrow appear in the top right corner of the RC?
    Jun 06, 2010 | Heating & Cooling
    How do I find degrees minutes and seconds on my ti 84 plus?
    On this family of calculators, you do as follows
    1. Enter the first number (degrees), ex:15
    2. Press [2nd][APPS] (ANGLE) to access the Angle functions
    3. Select [1: degree symbol] [ENTER]
    4. Main screen shows 15 deg
    5. Enter the minutes, ex 25
    6. Press [2nd] [APPS](ANGLE) to access Angle functions
    7. Select [2:' apostrophe] [ENTER]
    8. Screen echoes 15 deg 25'
    9. Enter the seconds number, ex 32
    10. Press [ALPHA][+] (") to access the double quotation mark.
    11. Screen echoes 15 deg 25' 32"
    12. Press [ENTER]
    13. Calculator converts this in decimal degrees 15.42555556
    To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
    Jan 11, 2010 | Texas Instruments TI-84 Plus Calculator
    If a textbook problem is given in DMS notation, how do I enter the DMS notation into the TI84 to get decimal degrees?
    Press [2nd][+] (") to access the double quotation mark
    Press [ENTER]
    Jan 06, 2010 | Texas Instruments TI-85 Calculator
    How to use the cosine,tangent etc functions of calculator fx-82ES plus
    1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
    2. Press the key for the function COS, SIN, or TAN
    [COS] displays Cos(
    3.Enter the angle 12 deg Screen shows cos(12
    Close the right parenthesis ) Screen shows cos(12)
    4.Press [=] Screen displays 0.9781
    If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1)
    arcsin [SHIFT][SIN] (sin^-1)
    actan [SHIFT][TAN] (tan^-1)
    You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results.
    Hope it helps.
    Nov 05, 2009 | Casio Office Equipment & Supplies
    I need to know where i can get a manual on how to set the remote controll for the air conditioner. right now we are turn them on and off every day or when it gets to hot or to cold. i would like to set...
    If its for the unit pictured go to http://service.airwell.com.au/airwellsanyoparts/Website%202007%20update/airwell/XV26RCA/ and click on operation instructions.doc. Even though this is an airwell manual, they both use the same control.
    Hope this helps
    Mat
    Jul 15, 2009 | Sanyo 18KHS72 Air Conditioner
    Heating & Cooling Logo
    2,247 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
