Question about Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228
Motor runs at low speed and trips breaker within 10 seconds
When motor starts, it does not get to normal speed. It seems to be struggling to go faster and then cuts outItrips breaker). I can reset the breaker, and same thing again.
    President:
  • 1,033 Answers
The motor is bad. It overheats inside and the contacts aren't releasing and this trips the breaker to prevent more damage, You can reset it because it had time to cool down and the contacts have released.
Posted on Jul 03, 2010
Ruud achiever 10 inside blower motor burning
Check fan cage to make sure it turns freely. Check voltage to IFM make sure it is correct for the application. Make sure the motor turns the fan cage in the correct direction. IFM will have high and low speed make sure when you change from fan on to auto that the motor changes speed. If you have an amp draw meter check to see when running the motor pulls the amp load it is rated for. Recheck all wiring.
Feb 29, 2012 | Ruud Matching Split Air Conditioner
Circuit breaker trips after 10 minutes
could be a weak breaker,or poor high resistance connection from panel to dryer plug, then have someone check the current draw on the dryer while operating and see if it's within specs of the machine tag, if it's higher than that you may have a defective motor or heating element to case causing a higher than normal current draw
Nov 09, 2009 | Maytag PYE2300AY Electric Dryer
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Delta table saw motor trips breaker
The motor needs a new start capacitor.
Apr 09, 2009 | Saws
Blowing the breaker
Sounds like you have a bad nutural feeding to the main or its set up for 110 and running on 220. Check the incomming voltage at the wire feed to the motor. If anyone has replaced a breaker or a wall plug close to the unit or any palce in the structure Im betting this feeds back to your air compressor some how. and somethign is differant than it used to be.
Their is no way it could turn faster unless the voltage is way up. Chack the Name plate also on the motor some are dual voltage and maybe its wired up for low volts and on higher. Catch it early like tbhis and it will be ok.
PLEASE RATE ME ACCORDINGLY I THIS HELPS. And GOOD LUCK
Mar 02, 2009 | Ingersoll Rand Compressors 5-HP,...
High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
Feb 01, 2009 | Rule H53sp 24mgra Swimming Pool Cover Pump...
Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228 Logo
197 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Mike Squire
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
