Question about Kenmore 22422 Top Load Washer
My washer, kenmore 90 series can agitate and complete washing cycle but will not drain and spine.
  • 259 Answers
Sounds like your lid switch is broken. This is located under the top of the washer and is activated by a tab that hangs off the side of the lid.
Accessing this part requires you to flip up the control panel by removing two phillips head screws in either the front bottom corners (may be behind the endcap covers), or rear bottom corners, pull panel forward and lift to disengage the tabs at the bottom. Flip the panel upwards and it will swing back out of the way.
Next you will see one wire connector going into the top of the machine, this is actually your lid switch connector, disconnect it. Now using a flat screwdriver pry the front of the two brass clips towards the rear of the washer (put tip of screwdriver into front most part of clip and press handle of screwdriver towards rear of machine). The clips should pop off the top pretty easily.
Now you can open the lid and place a hand on the front of the opening and pull the cabinet forward. The entire front and side wrapper will come off the base platform and you can set it on the floor to gain access to the lid switch that is screwed to the underside.
Good luck to you on this!
Posted on Jul 03, 2010
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore 90 Series is NOT DRAINING or AGITATING
motor to transmission coupling or transmission itself.
Jul 02, 2009 | Kenmore 23822 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore Washer Model 100, 90 series fills and agitates but
most common solution is to replace the lid switch. (the machine thinks the lid is still open)
Dec 26, 2008 | Kenmore 23822 Top Load Washer
Kenmore 70 series agitates but does not drain or spin cycle.
If the unit is not draining or spinning it sounds like a lid switch. If the unit is draining but not spining it sounds like a drive coupling.
Dec 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore electronic 90 series washer
easy easy you need agitator dogs thats right the official name of the part is agitator dogs! 5 dollar part can chat you through the fix
Mar 25, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
113 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
