Trane serial number B32052929 is not cooling sufficently model number is BTD724A100C2 approximately 8 years old. What BTU unit is it
  • 74 Answers
24,000 or a 2ton
Posted on Jul 03, 2010
How many btu in a PD121-5 on a air conditioner .
What is the brand, model number, serial number, year of manufacture? BTU = British thermal units, this i s heat reference not a cooling reference.
Apr 12, 2015 | Heating & Cooling
How do ifind the btu for my cz-10rt32p air con
Air Con Model Numbers normally have the capacity of the unit within the Model Number, but not always. It would look to me as if your unit was a 32,000 BTU unit, but I could be wrong. It should say it on the label. It can be displayed in BTU or Tons. One Ton = 12,000 BTU. For example, if your label says 2.5 Tons, multiply this by 12,000 and you'll get the total of 30,000 BTU.
But if you can't find it on the label or the label is missing, you can get an approximate by measuring the room the unit is cooling/heating. The formula for calculating this varies from place to place due to weather conditions, and maximum/minimum temperatures where you live.
I live in the Caribbean and it is very hot here all year long, so we use this formula: length x width x 85°F
But this formula will be different if you live in the northern parts of the country. Do a research online to find the correct formula for your area if you need to use this method.
Dec 02, 2014 | Panasonic Heating & Cooling
What is the age of the following Carrier RTU - Model # YCDO6OC460BF & Serial # R28105287D I have been told 1982, 2000 & 2007. The unit does not look that old, so do not believe it was a 1982,...
YCD060 is a Trane unit number not a carrier. Trane has a large guide for looking up approximate age of equipment. There is no date coded in the serial number, Trane does include a mfg date on most of the labels on later equipment, look for it on top or bottom corner of label if you can still read it otherwise I have the cuide at the office and will look it up this week. FYI our company is a TCS Trane dealer.
Aug 24, 2011 | Heating & Cooling
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
I have a Trane Model # TWE048C140C0 Serial # 2261X5Y2V what is the ton rating for this A/C unit?
The tonnage of this unit is the 48 you find in the model. Each ton of cooling equals 12,000 B.T.U. So, 48 would be a 4- Ton Unit. 48 divided by 12 =4x12=48.
Shastalaker7
Feb 22, 2010 | Heating & Cooling
I need to know the seer number for an air handler. I'd
On the air handler take the top panel off, look to the left on the inside, this will give you general information on the unit on a stampede plate. This will
give you the date of manufactuer as well.
On the outdoor unit, there is a stamped plate on the
condensing unit. Should have year of manufactuer, it
should also say how many pounds of freon should be
in it. The Model number is what you need to know
to find out how big it is.
024=24,000 BTU= 2ton unit
030=30,000 BTU=2 1/2ton
036=36,000 BTU=3ton
040=40,000BTU= 3 1/2ton
and so on.
My guess is that it is an older unit and since I have
been installling units since 1995 I have only known
any older units to be at least a 10 SEER and no more.
Feb 16, 2010 | Heating & Cooling
Need the BTU rating for an old Kenmore K948991 a/c
Your model number is not complete enough for a model check.
However, 18,000 btu in todays' units is what you need.
Mar 28, 2009 | Kenmore Heating & Cooling
What is the tonage of this model no.
It looks to be a 2 ton unit according to model number it is a 24,000 btu unit 12,000btu's to a ton as far as age I'm not sure how to read thier serial number but guessing I would say 2002 was the year mfg in the 13th week. thanks peyton
Mar 20, 2009 | Heating & Cooling
No heating, cooling or fan.
I'm confused. You have a Trane, but are asking about the Goodman warranty. I missed something there I'm sure, sorry.
"IF" Trane has a recall or warranty issue, then any qualified technician should be able to help you with that. The parts would be provided by trane in such an event, but unless the unit is less than 1 year old, chances are you will have to pay for the labor.
Being an electricain help if you want us to assist you in troubleshooting.
This link takes you to the TRANE contact page. They can answer any warranty/recall questions you have.
Jan 21, 2009 | Heating & Cooling
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
