Question about Dell Inspiron 1525 Notebook
Spilled about 1/4 cup liquid (iced tea) onto laptop keyboard and computer shut down. First I turned over and drained liquid from keyboard. Second I removed battery hard drive and optical drive and am letting them air out although I am not detecting any liquid on these parts. What else should I do? many many thanks. abbey
  • 484 Answers
... continuing this suggestion ... my PC seemed to think I had finished my answer. I had not, I must try to complete it now. So I will try to pick up where I left off:
Do the hair dryer treatment for a few days. Once you have done it that way there are two more things:
1) Pray, and 2) Try to start this laptop again.
Remember that in a computer, especially a laptop, almost all parts are solid state of one kind or another. Which means tha so long as you treat things carefully, and do not try anything esoteric with the guts of the laptop, everything should be fine, once all has been dried out.
Given that all parts can be brought back again to a usable state, your patience and giving it the necessary time to dry out completely, your laptop should be resurrected, if given the time to do so.
Good Luck,
-a.
Posted on Jul 10, 2010
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
Tip
Spilled liquid on Keyboard!
1. Purchase plastic keyboard cover. 2. Keep coffee etc. anywhere not near keyboard.
For spill, unplug keyboard. If non sugar liquid, invert keyboard, shake or tap gently. Wipe with lent free absorbent cloth while still inverted. If soda or coffee with sugar, pour 1/4 cup of clear clean (distilled the best) water onto keyboard (yes), Then invert. Let dry a minimum of several hours still inverted. I cheat with a hairdryer on low 6-12 inches. After keyboard is completely dry (and cool). Plug in after turning computer off, restart, test all keys, including shift, option etc. If keys miss or don't work buy new keyboard and cover! Aloha, Cliff
on Sep 27, 2014 | Apple 24" iMac Desktop
Spilled tea on keypad of macbook now it doesn't work
Open laptop and lay on heavy towels with the keyboard facing down, remove charger and main battery, most of the tea should drain out in this position, contact a service centre to assess the motherboard, sooner the better.
Jun 17, 2012 | Apple MacBook Pro Laptop Computer with...
I spilled I tea on my Gateway FX keyboard and mousepad. The keys are working now but I'm worried they will get sticky. I cleaned up as much as possible by patting with a towel to soak up the tea. ...
Before you do anything, unless it is already dried, (turn it off first!) turn the laptop upside down and gently tap the back to coax any liquid out. Then do NOT turn it on until it is totally dried. You can clean the keys and pad it with a DAMP (NOT wet) cloth with plain soap and water. Be careful not to get any water down into the keyboard itself so it doesn't short it out. However this will not clean whatever liquid may have gone inside. Hopefully none did else you could end up with a bigger problem...
Jul 16, 2011 | Gateway Computers & Internet
I spilled hot tea on the key board and it turnned off
When this happens, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard
Nov 22, 2010 | Panasonic Toughbook CF-51 Notebook
Coffee got spilled on my laptop keyboard. The laptop seems to work fine all except for the keyboard. When I push the keys, something different shows on the screen other than the letter I pushed. Like if I...
How to Fix Spilt Liquid on bda25ce.jpg?
You accidentally knocked fruit drink or a late night glass of milk on your laptop or your child spilled a good portion of milk directly into your keyboard. You hear a popping noise, the screen goes black. Water by itself is not as bad as milk or juice, both of which are corrosive/acidic, or coffee, tea, soda, etc.
First and most important -Calm Down and unplug the computer from its power source.
Disconnect it from the power cord and remove the battery. If needs, please remove the keyboard. The old adage - Water and Electricity don't mix - is quite true. For your laptop spilled water, let your laptop dry. Do not attempt to turn on the computer for at least 72 hours. Let it sit in a cool, dry place. If you disassembled the laptop, reassemble it after 72 hours have passed.
Oct 13, 2010 | Computers & Internet
Spilled liquid on keyboard, need to remove keyboard to try and clean up spillage. cant remove keyboard because of the power button
if the computer is on, u cannot remove keyboard for safe purposes. u can press cpu power button for a long time till the computer shuts down. this shuts down the pc safely. after the pc shuts down remove the keyboard. u can either clean it or replace with new one.
Feb 19, 2010 | Gateway M685-E Notebook
I spilled tea on my packard bell easynote
Two things to check.
Open the laptop up and re-connect the keyboard connection. It has a locking mechanism so be sure to unlock that first. Also when you're doing that you can see if there's any water (tea) still in there to dry off.
If that doesn't work, then plug in an external keyboard mate, cause the only other way to fix this is to replace the keyboard, the parts to open up the laptop keyboard itself are intricate and it's much too compicated, plus I've never done that (Seeing as that it's all glued together).
Hope this helps, be sure to rate!
Jan 03, 2009 | Toshiba Satellite M45-S165 Notebook
Tea spilt ok Thinkpad Keyboard
I'm sorry, but there are no alternatives, and you may have bigger issues than just the keyboard. If the tea seeped past the keyboard, and onto the motherboard, which is directly bellow the keyboard, then by trying to start it you may have fried the motherboard. You would be surprised how long it takes for a laptop to dry out, 6 hours is not near long enough. You will also want to clean it, the sugar in the tea can cause corrosion of the circuitry on the motherboard. I'm going to recommend that you take it in for a professional diagnostic and cleaning. This way you will know the exact extent of the damage.
Sep 03, 2008 | IBM ThinkPad T30 2366 Notebook
Acer Aspire 5610 - one key does not work
Laptop keyboard are semi-sealed circuit boards. This means that liquid can get into the contacts and can not be cleaned. Depending on how much liquid was spilled on the keyboard chances are that the liquid has seeped around the edges of the keyboard and down onto the mainboard of the laptop. My first suggestion would be to keep the laptop turned off until you can remove the keyboard and check for liquid damage to the mainboard. If there is no damage to the mainboard I would suggest buying a new keyboard before turning the computer back on as any shorts caused by the liquid damage on the keyboard can cause damage to the keyboard controller circuit on the mainboard.
Jan 03, 2008 | Acer Aspire 5100 Notebook
Dell Inspiron 1525 Notebook Logo
153 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
