How to change my ink in my printer, it keeps saying no ink but it has the things inside, what do I do?
    Guru:
  • 1,463 Answers
Hi
can you post your make/model of the printer so help can be given
regards
riz.
Posted on Apr 17, 2008
Iv changed my ink cartridge and now it wont print it keeps saying ink cartridge has been changed
I just got mine working again. Solution: You have to disassemble your Printer. Take a close look at the small round motor inside. Their is a small toothed wheel attached to the shaft of the motor - mine was already lying inside the printer. This wheel hast to be replaced by a tighter fitting one or the original one has to be fixed to the shaft - I used glue, as i had no new wheel.
May 10, 2012 | Canon SELPHY ES2 Printer
Our machine says 'waste ink near full' what does this mean?
There are pads inside the printer that collect excess ink and hlep to keep the print heads clean , and they need to be changed.
Oct 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
My Epson rx595 keeps saying replace ink cartridges B78/77 which i have and then it is also saying that it cannot recognize ink cartridge B78/77 I have loaded 3 brand new cartridges in thus far and it keeps...
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Mar 22, 2010 | Epson Office Equipment & Supplies
Alignment problem on lexmark x4650 printer
Try this
Turn off you printer
remove the cartridges
and try gently moving the ink cartridges carrier from left to right
for about a min.
also you can try to wipe machine oil on the bar that holds the ink cartridge carrier
then put the cartridges back inside the carrier
then turn on you printer
and try to print again
If problem persist
TRY THIS:
turn off your printer
unplug the power cable from the printer
lift you printer and put it in an upside down position
then shake the printer from left to right
see if there's any foreign objects stuck inside the printer
Feb 25, 2010 | Lexmark X4650 InkJet Printer
INK CARTRIDGES ALL NEW. SAYING THEY ARE EMPTY
Hi, i think during the process of changing the cartridges, the top lid on the ink cartridge that clips or keys the cartridge down inside the printer has been broken and needs to be replaced.
I suggest you get a technician to help get a replacement for this. With this your printer should be in other.
Jan 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
My printer keeps on blinking error for no ink and
If by "just changed the ink "you are trying to say that you have just recharged you printer's cartridge then don't put this question to yourself because this happens when the printer figures out that the cartridge is not original!
Dec 19, 2009 | HP DeskJet F380 All-In-One Printer
I have changed inks keeps saying low on inks yellow empty wont print
tape up the side thats the outside theres a black bit inside just cover it up that will do it
Oct 25, 2008 | Brother DCP-110C All-In-One InkJet Printer
Canon mp500 printer
plz check you have placed the ink tank in the appropriate slot otherwise you have to try with new one
Aug 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Changed blk ink cartridge and it says NO CARTRIDGE
see/search brother faQ:
http://www.brother-usa.com/FAQs/faq.aspx?Model=990&ProductGroup=5
Nov 09, 2007 | Brother Multi-Function Center MFC-3360c...
Epson stylus c66
If your having an error that says "Parts inside the printer are at the end of there Service life" it means that you ink pad is full/ what you can do is change your ink pad and then download an ink pad reset utility so that you can reset the settings/ Make sure to change ink pad before you reset it becuase ink will leak if you don't change it. For the flashing lights, try to check for obstructions inside the printer if not, make sure that ink clicked in and the cover for the tray is closed
Mar 27, 2007 | Epson Stylus C66 Inkjet Printer
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
