Question about Sony PS-LX250H Turntable
My drive belt was taken off the record player and i cannot figure out how to get it back on
  • 10,594 Answers
Let me know model number of your Sony record player to help you out.
Model number would be written on rear or bottom of unit.
Thanks.
Posted on Jul 03, 2010
  • Shahid Electronics
    Shahid Electronics Jul 03, 2010
    Need to pull up platter mate then platter, fix belt around platter and hook some wire between platter, turn it in U shape and rubber belt, this wire will support to pull rubber belt to set it on motor that located chassis of record player.
    Now place back platter on its center shaft but do not let it go all the way down, pull that supporting wire and seat the belt over motor pulley, then press down platter to fix in its position. Now slowly pull one side of supporting wire so it came off from belt and platter.
    slowly rotate platter to confirm belt is fixed properly on motor pulley. Turn power On and confirm platter rotation.
    Following exploded view taken from service manual will help you.
    Thanks.
GE 3-5027 portable cassette player/recorder belts
I have a GE Battery operated Cassette Recorder, model no. 3-5025A and the spinals that turn the the cassette will not turn. I believe I need the 3 tiny belts that make it work need to be replaced. The are different sizes, do you know where I can purchase these belts?
Mar 15, 2014 | General Electric Cassette Recorder &...
RECORD PLAYER PROBLEMS
Belt is to small or tight--exact belt type on capstan is required--if the old belt works at all try putting it back. Not many DVD players use belts much anymore.
May 02, 2012 | Televison & Video
I have a JVC VCR/DVD-recorder, model DR-MV7S. It developed a problem... when you placed a DVD on the tray & pressed the "eject/open" button to take the DVD into the recorder, the tray...
This can be due to a faulty LOADING drive settings, It can be due to a misalignment of the loading section and so the load does not reset to the PARK CONDITION of the MODE.
It can be a aulty gear, belt or jamming in the drive.
You need to open the player, remove the mechanism and manually check the forward and loading motion which can confirm. If the belt or the drive is jammed this can be checked and replaced or reset.
Check the mode switch settings of the forward loading.
Sep 19, 2011 | JVC DR-MV7S DVD Recorder/VCR
I have the sony record player above, and when I was moving I put it on its side and the belt came off. Now I cant figure out how to put it back on. Help ?
The Operating Instructions link on this page:
http://esupport.sony.com/US/perl/model-documents.pl?region_id=1&mdl=PS-LX250H
appears to give guidance on connecting the belt. Any use?
Oct 13, 2010 | Sony PS-LX250H Turntable
Turntable won't turn
There is usually a cotter pin at the center of the platter around the spindle base. This can be removed with a screw driver using a twisting motion. There is a blades worth of space between the clip and the spindle base. Screw driver should be in vertical position. Sometimes the vinyl slip mat must be removed first. Watch that clip, cause it can go flyin. Once the clip is removed, the turntable should let go easily.
May 03, 2009 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Intermittent Recording
in you menu change your video format , check all settings,what type disc are you using ? are you recording to hd or to dvd, ? check your
firmware update
still have problems call 0403960527 jeff
email jcshepard55@hotmail.com
Feb 16, 2009 | Panasonic DMR-EH75 DVD Recorder/VCR/HDD...
Record player belt
Scott, the belt wraps around the bottom of the turntable platter, then put the platter back on your turntable, and you'll have to pinch back a section of the belt and wrap around the brass motor spindle. That's pretty much it!
Good luck.
- OPTiC
TWEAK A/V LAB
Apr 13, 2008 | Technics SL-1200MK2 Turntable
Has had 2 different problems
your set needs to be taken to a tech for repairs it is having a micro computer problem.good luck
Apr 02, 2007 | Panasonic DMR-E80H DVD Recorder
Sony PS-LX250H Turntable Logo
826 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
