Question about Whirlpool AWM5125/1 Front Load Washer
Extreme vibration from the tub - Whirlpool AWM5125/1 Front Load Washer
  • 6,784 Answers
A washing machine can wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be many causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load(typically). Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you tend to wash a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced.This is another area of concern. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
In order to access these vital parts,Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
You should find the culprit in one of the areas above.
Posted on Jul 03, 2010
How to repair a loose drum?
You need to remove the agitator, loosen the tub nut (May already be loose), align bowl & tighten tub nut.
Mar 16, 2015 | Maytag Washing Machines
Ge super capacity plus washer
It sounds like your bearings are are whacked, if you have vertical
movement in the drum the bearings will need replacing , not a simple job as seals also need replacing
Dec 20, 2013 | Washing Machines
Frigidaire fws747rfs1
The washer tub bearing may be defective, but that is the only thing that I can think of. Are you noticing this on all loads or just heavy items like bath towels and jeans? Are you redistributing the clothes before the final spin, try that. Also do not overload the washer, wash to medium loads instead of one full to the top load. Wastes water but saves on repairs.
Apr 12, 2017 | Washing Machines
Hello i have a maytag neptune front loader that ive had for only two years and it was making an extremely loud noise when spinning now it has stopped spinning completely and my clothes are still soaked...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 18, 2011 | Maytag Washing Machines
Wash machine vibrates moving several feet on fast spin cycle
If the suspension is still flexible, any unbalanced load will cause this. If it is accompanied by the tub striking the inside of the stationary tub, one of the suspension points may have failed.
I would remove the lower rear panel and watch the movement (with a good light) of the outer tub while a helper pushes the inner tub to its extremes to see if one of the points is 'unhinged.'
Jan 29, 2010 | Kenmore Washing Machines
Kenmore HE2 washer, extreme vibrations in spin cycle.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 04, 2010 | Kenmore HE2 Plus Front Load Washer
Tub vibrates and hits side walls on spin cycle.
Open the top, and look for worn or broken vibration dampers between the outer tub and the cabinet walls. Shake the tub to help locate the problem areas. Hope this helps!
Jan 02, 2010 | Washing Machines
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Mar 17, 2009 | Kenmore Washing Machines
I have a whirlpool top load washer.. mod number lsr5132pq4 and when it spins out it shakes and vibrates extremely loud
Dec 27, 2008 | Washing Machines
EXTREME SHAKING DURING SPIN CYCLE
Whirlpool AWM5125/1 Front Load Washer Logo
129 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
