Question about Air Tools & Compressors
Location of reset button on pancake compressor motor-compressor low on oil, overheated but is not froze up
  • 21 Answers
Lucky. fill with oil but don't over fill. reset button is on the side.just reach under plastic cover you will see a black button push it in and try again. good luck
Posted on Jul 04, 2010
HDC 2HP 5 Gal Pancake Air Compressor - replaced pressure switch - now takes long time to pump tire - motor runs long time - slow recovery - actually overheated and melted off the plastic part on muffler....
Barb:
Your compressor takes standard 30 weight compressor oil or 30 weight motor oil... you need to put in the correct amount. The slow recovery is due to a leak somewhere. after adding the proper amount of oil, run the compressor and use a soapy solution to check for leaks. Check especially the tube that runs from the compressor head to the tank, and also check the air connection at the pressure switch. When you find the leak, you can disconnect the connection and use Teflon tape on the male end connector.
Aug 15, 2013 | Air Tools & Compressors
I have a newer Bostitch Air Compressor and it worked just fine a month ago and now we plug it in and the motor doesn't even turn on. And, no, it is not the outlet.
It is not uncommon for these compressor motors to "burn up". They are especially prone to overheating if a 14g or 16g extension cord is used to power it. Most of these do have a motor thermal protection button. Look carefully around the motor and motor mount frame. Of course, tracing the electric with a volt meter will confirm the location where the voltage terminates. The Auto/Off pressure switch is another possible fault. Taking the motor leads and powering them directly with 120v will confirm a motor problem. If this is an Oil Lubricated pump then double check by removing the back of the motor cover and turning the fan by hand. If unable to turn.. the pump may have froze up due to lack of lubrication. Usually a pipe wrench turning the exposed motor shaft will unlock the crankshaft and a high grade synthetic non-foaming motor oil in the crankcase will help keep it lubricated and it may contimue to work okay.
Oct 16, 2012 | Stanley NEW Bostitch 2 HP 6 Gallon...
What kind of oil do i put in my clark 4gal pancake compressor
If it's an oil-less, none. If it's a regular compressor, use compressor oil.
Jun 02, 2012 | Clarke Power Products Inc AC2001 2HP 4...
I have a model cw0100 1hp 4gal. and need to know capacity of oil tank.
Check you model number. I don't think cw0100 is correct. Most 1HP 4 gal pancake compressors are oil-free.
Jan 09, 2011 | Stanley FactoryReconditioned Bostitch...
Type of oil used in ac2001 air compressor
It should take any standard compressor oil, available and Home Depot, Lowe's, Sears, and auto parts stores
Jul 11, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Motor startup trouble while pressure in tank
My first thought was that the check valve is allowing pressure back into the compressor and preventing the motor from turning. That's still my best guess right now.
I think the cold weather start symptom is what you would see with any engine/motor -- it requires more torque to get it going. In this scenario, if the check valve weren't leaking, it would start okay when cold.
May 06, 2009 | Clarke Power Products Inc AC2001 2HP 4...
WON'T RESTART
The reset button used on Bostitch is the type that cuts out when motor is too hot to safely run. You must wait till system cools a bit before the reset button will reset. May be a good idea to solve overheating problem before replacing reset. It is always best to connect the compressor directly to the outlet instead of using an extension cord. If it is already connected directly to plug, insure that the outlet is capable of delivering amps needed for your compressor. When the compressor reaches rated pressure and shuts off there should be a small release of air from the pressure switch. This release of pressure allows the compessor to start in an unloaded state. If the compressor does not release the air in the hose the motor will not have the power to overcome the backpressure and cause the reset to open. There is a capacitor that could be at fault. The capacitor must be removed from the circuit to test. It should test within 95 percent of rated value. Generally, overheating is caused by low power. A failed capacitor is caused by low power. Good luck, enjoy.
Dec 24, 2008 | Stanley Bostitch CWC200ST 3HP Oil Lube...
Air Tools & Compressors Logo
141 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
