Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
How do i back wash my 635T pump - Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
We haven't used our pool yet I put pool chemicals in to clean pool and the pump won't turn on it has 635T filter pump , the light doesn't even come on the pp when plugged in? What do I need to do?
Check the breaker feeding the pump and make sure that power is reaching the motor. If there is a timer make sure that it is in the "on" position.
Aug 06, 2015 | Pool & Spa
My krystal klear model 635t pump won't turn on. just hooked up for the summer and the reset is operating but won't turn on. what can i try?
when a pump motor has been sitting for a long time and will not start ,it indicates that the armature of the motor is seized from a rusted bearing ,normally at the pump end of the motor
you say the reset button works and for that to be in a position to work the motor is not spinning and the overload is putting it out to stop burn out
It may be wise to have it looked at by an accredited pump shop
Jun 12, 2015 | Pool & Spa
What would be the best automatic pool cleaner for intex 18 x 48 easy set
try to get the vacuum that works with the garden hose they work ok for the small pools
Sep 09, 2014 | Intex 18 ft x 48" Easy Set Inflatable...
The pump's hoses leak where they are attached to the pool. Do I need a gasket?
depending on how yours is hooked up, you need to either remove the ***** in fittings and retape with teflon or retighten the clamps holding the hoses. i always use two clamps, one facing each direction
May 28, 2014 | Hayward 1 Hp 2 Speed Super Pump Inground...
How much horsepower does my intex Crystal Clear Model 635T filter pump have? I'm looking at a hth vacuum that requires at least 1/2 horse power. thanks
If the unit does not have the horsepower rating, but has the AMP rating, try this formula found in Answers.com
"Amps are a factor in calculating power, and so can be used to determine horsepower, but only when other factors are present.
Given other factors, you can find the horsepower. The easiest way is to determine watts by multiplying amps X volts. Next multiply watts by .00134 and you have horsepower.
If: amps (A)= 20 and volts (V)=120 then
A X V =2400 watts (W)
2400 watts X .00134 = 3.216 horsepower"
Hope this helps you???
Aug 14, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Water leaks out the top of the filter housing. I ordered "o" ring 10266 (filter housing "o" ring) and it is too larger. Where can I find a schematic with part numbers.
Here's the diagram for the 635T.. The o-ring for the top valve should be part number 10264- #3...small o-ring. The housing cover is the bigger o-ring 10325 #5.. Hope this helps you...
Aug 11, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
67 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
