Question about Broderbund PrintMaster Platinum Version 18
I am trying to install printmaster Platinum 18 on my Window 7 Computer and it alway stop and said Error 1311 why
    President:
  • 2,340 Answers
"Error 1311" -Source file not found.
Maybe this workaround may help.
1. http://support.microsoft.com/kb/325076
2. http://www.ehow.com/how_5556804_fix-error.html
Posted on Jul 06, 2010
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I HAVE A VISTA 'HP' PAVILION LAPTOP. I HAVE JUST PURCHASED YOUR 'PRINTMASTER' PLATINUM VERSION 18. I HAVE BEEN UNABLE TO LOAD IT ON MY COMPUTER. I HAVE MISPLACED THE DIRECTIONS THAT CAME WITH THE...
Check this link for the step by step way in installing this software but this is for 'PRINTMASTER' PLATINUM VERSION 17 but dont worry its just have the same procedure in installing the 'PRINTMASTER' PLATINUM VERSION 18, this is the link
http://support.broderbund.com/fix.asp?isid=44677&prog=1294820935&printer=1
Hope that helps.........
Aug 13, 2008 | Broderbund PrintMaster Platinum 16
Our business has been using Printmaster 15 for a few years now. We recently bought a new computer with windows 7. Printmaster 15 is obviously not compatible with Windows 7. I bought printmaster 2011...
You can try version 15 in compatibility mode:
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows:
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Jul 19, 2017 | Broderbund PrintMaster Platinum 16
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Feb 18, 2011 | Broderbund PrintMaster Platinum Version 18
I installed window 7 into my laptop. My printmaster platinum 18 is now not working properly. What can I do to resolve this issue
Right click on the program shortcut click on properties from the menu and click on the compatibility tab , check "Run this program in compatibility mode of windows xx" and select the version of windows in which the program used to run. Apply the settings and open the program again. If the program still doesnt work try to reinstall or get an updated version for windows 7 maybe Print Master 2010.
Sep 12, 2010 | Broderbund PrintMaster Platinum Version 18
I have chnged my computer system form XP to Window, now I cannot install PrintMaster Platinum Version 17? Is there any way that I can istall this program disc?
Thank you for your question.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
All the best with your install.
Kind regards
Jul 20, 2010 | Broderbund PrintMaster Platinum Version 18
Need a patch for printmaster platinum 10 for windows 7
my wife has a dell computer with window 7 professional operation sistom and i have printmaster platinum 10 only for Windows 95/98/200 NT 4 how i cann install this program in the new computer?
May 31, 2010 | Broderbund PrintMaster Platinum 16
I bought a new computer with Windows 7. Is Printmaster 18 compatible? I have started to install it but a message came up stating there were 'compatibility issues' Is this correct and if so, what can I do?
This should answer your question
I understand that you are inquiring if Printmaster 18 is compatible with Windows 7. Our developers have tested every aspect of Printmaster 18 to see if it will function properly on Windows 7. It has passed all tests except one, which is the Save As PDF feature. Our developers just became aware of this and are working on a resolution to make it work on the Windows 7 operating system. We apologize for any inconvenience this has caused, but we can assure you that we will provide a fix for this as soon as possible.
http://www.broderbund.com/store/broder/Content/pbPage.ProductSupportMain
Jan 10, 2010 | Broderbund PrintMaster Platinum Version 18
Cannot find installation CD for Printmaster Platinum 10. What can I do?
Buy version 18 (not '10') online:
http://www.hermanstreet.com/store/smarthtml/printmaster-platinum.html
Note that there is a "pop-up" window that gives you 20% off their price ($34.95) if you buy online within one hour of _first_ viewing the above web-page.
Sep 19, 2009 | Broderbund PrintMaster Platinum 16
Broderbund PrintMaster Platinum Version 18 Logo
302 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
