I have a CCD Barcode Scanner Type:FG-8100 scanner, how can I connect it and set up to POS?
5 Suggested Answers
SOURCE: it3800 barcode scanner problems
Will it scan data into excel or word?
Posted on Aug 05, 2008
  • 25 Answers
SOURCE: Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
Posted on Jan 23, 2008
SOURCE: DS6708 symbol scanner freezes keyboard
Have you tried taking the battery out of the scanner and then reinserting it? THis should reset the scanner to some degree.
It really depends which barcodes you scanned in the manual.
Your best chance seems to be a reset to the original settings, for which you may need to look at the manual.
Posted on Mar 18, 2008
SOURCE: How can enable Barcode Scanner ??
You have to use a program which will activate the scanner.
You can use DataWedge, which will send the scanner input to whatever has focus: https://docs.symbol.com/KanisaPlatform/Publishing/968/KB100417_f.html
Posted on Oct 07, 2008
Usb port open error
Does it work on other POS machine? That is to verify any hardware issue with the scanner. If it works, does other scanner works on this POS machine? Sometimes unplug and replug some USB cable in or some of the cable in between the POS and scanner will make it work. If those do not work, try to check the server for POS connection and see whether they can see that POS system. Use your store control application to reset that POS machine before you refresh the software or operating system on that.
Sep 11, 2012 | Datalogic Magellan 1100i Barcode Scanner...
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
Scanning is extremly slow
What interface? If it is a USB interface the scanner sends the numbers the same as if you had entered them on the keyboard. If you do just enter the barcode (need to know format actually sent to application) numbers does it also respond slow?
Plug the scanner into another PC/laptop, open notepad and scan a barcode, does it scan fast?
The POS application, if it is windows, open notepad and scan the barcode, does it scan faster.
It is likely the POS application that is responding slow.
For the POS applicaton:
- Is scan database local or on the network.
- Have you maintained the scan database? Re-index, compacting, etc
Apr 13, 2010 | HHP 3800g Handheld Barcode Scanner
Symbol barcode scanner LS4071 + base RL475
Hi, you will need the 25-17821-20 and STI80-0200R cables to connect to PS/2. You must have a PS/2 keyboard for this connection.
If you would prefer to connect to a USB port you should get the 25-17821-20 cable with the STI85-0200R.
The RL-475 was for the IBM, but it also supported Synapse which is the STI cable.
Nov 18, 2009 | Computers & Internet
CRE POS serial scanner doesn't scan
you can try to use a software package called Twedge...I've used it to solve issues just like you have above with a scanner scale and a Y cable...
May 29, 2009 | NCR 7875
Transfer info from the digital weight scaleto quickbooks
You would need to add an criteria or the rule, like barcode length or type. Than is the the scanner able to understand which barcode should be handled by the specific rule.
Dec 03, 2008 | Symbol LS2208 Handheld
Problem with scanner
I have it connected to keyboard port as they instructed.
Sep 02, 2007 | HHP 3800 (015305) Handheld
Computers & Internet Logo
871 people viewed this question
David Payne
David Payne
