The water wont drain out off the washing machine there is an error code UE is flashing and it wont finish spinning i have taken off the drain pipe and its not blocked and i have emptied the water via the bottom with no luck i have a front loader NFL-1065 is there anything else we can do before getting a repair man out?
  • 975 Answers
YES ! there is something else , check the little MOTOR that is attached to the drain hose , take it out , take it apart and check if there s some stuff blocking the motor inside ,hopefully this will take care of the problem .
Posted on Apr 17, 2008
My lg tromm wm2277hw keeps giving a ue error at the last spin cycle. It even occurs when the washer is completely empty so it can't be an uneven load. It drains fine beforehand but always leaves a little...
it could be that the water sensor is not resetting, take the back off remembering to unplug the machine and look for a small 5mm pipe leading upwards, take it off and blow gently into it, you will hear a click and one when you release the air, if so then the place where you took the pipe from is blocked preventing the water sensor to work properly, so unblock the pipe with a pipe cleaner or a metal rod to unblock it, replace the pipe and run the machine again eric
Jan 16, 2018 | Washing Machines
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Dec 26, 2013 | LG WM1812C Front Load Washer
It flash 2 then 0 and it wont drain or spin the clothes
F20 error code indicates no water detected entering the washer. Be sure the drain hose is not down too far into the drain stand pipe & both hot & cold water is turned on & working.
Jan 18, 2011 | Maytag EPIC MFW9700S Front Load Washer
Error code UE on LG F1247 TD5 washing machine
it means uneven load do u have a pillow in there or something that soaks up lots of water!!
Oct 28, 2009 | LG Washing Machines
My samsung 7kg front loader keeps flashing UE on the error code (spin cycle) and I can't open the door
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 26, 2009 | Samsung WF337AA Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
Jan 09, 2008 | LG WM2077CW XL Front Load Stackable Washer...
Ue error code on the display
For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
Sep 23, 2007 | LG WM1814CW Front Load Washer
Washing Machines Logo
237 people viewed this question
Top Washing Machines Experts
