Question about NEC Versa VX Notebook
Can't see my screen on my laptop and i want to put it through to an external tv screen. How do i do this, i also was given a VGA cable.
    Scholar:
  • 94 Answers
To hook up the monitor all you will need to do it connect it to the monitor port on the side or back of the notebook it should just start displaying on your external monitor as soon as you hook it up but if it dose not you may need to restart the system. Also the port you need to connect to is the only port on the computer the monitor cable will be able to plug into so don't be worried about connecting to the wrong port on your notebook.
I hope this helped.
Thank you,
Norse
Posted on Jul 02, 2010
My screen keep going white
To me this is a hardware problem.
Let's diagnose, and see Shunka_Reid.
Connect a VGA monitor to the laptop.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78lv.shtml
Number 3 - External VGA display port
General example of VGA connector (port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
General example of a CRT type of monitor,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY.
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap on the F4 key once more.
Do you get a good display on the external VGA monitor?
Post back in a Comment.
Also, has the laptop ever been cleaned on the Inside, to your knowledge?
Regards,
joecoolvette
Mar 04, 2013 | Gateway NV7923u 173Inch Laptop (NightSky...
MY acer ZD1 screen has gone black how do i connect it to a pc screen blind
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the Right/Rear of the laptop.
Example of a VGA connector (Port), and a VGA Cable,
Scroll down a little for an example of a VGA Cable.
Yes. You can also connect an HDMI cable to it, and HDTV with this capability.
Turn the laptop on.
By factory default settings the display should show on the external VGA monitor.
If not;
There are at least 3 display options;
Press, and hold down on the Fn key. At the SAME time tap once on the F5 key. The F5 key is the Display Toggle-Over key.
Regards,
joecoolvette
Feb 19, 2013 | Acer Aspire 5920-6423 Notebook
Screen will not load just white lines
Does external display work fine? If you have not checked, connect an external display like desktop monitor or a LED TV which has VGA connector to your laptop's vga port. You may have to use some fn keys combination to switch from laptop display to external. If external display works fine then check the display cable connecting laptop motherboard to laptop display. And also check laptop LCD/LED screen. You may have to try another with another screen in such scenario.
Sep 17, 2012 | Pavilion g7-1219wm Notebook PC
When I turn on my HP Pavilion 1x1000 It stays on ,but there is no image on the screen, and stays on please help.
A) Post THE Product Number on the bottom of the laptop. It's in the white Service Tag. P/N = Product Number.
B) On the left/bottom side of the LCD screen frame (Display Bezel), there is a switch. Looks like a small button.
This is the Internal Display Switch. (May not be in this exact position for your model. Look around on the Display Bezel, that surrounds the LCD screen)
When the laptop is closed, the switch turns off the display, (Image on screen), with the computer still on.
Tap it a couple of times lightly, with the eraser on the end of a number 2 pencil.
See if anything happens. That switch may be bad.
C) Laptop off, monitor off, connect a VGA monitor to the VGA port on the laptop.
Example of a VGA cable, and VGA connector, (Port),
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
C) Turn the monitor on. If a CRT type of monitor allow it to warm up.
Turn the laptop on.
IF not;
There are at least 3 display options,
2) Internal monitor AND external VGA monitor
Press, and hold down on the Fn key. At the same time tap once on the Display Toggle-Over key.
Don't know what exact HP laptop you have. For most HP's it is the F2 key, or the F4 key, that is the Display Toggle-Over key.
(Key has an empty rectangle on it, with a vertical line on each side)
Still no display on the external VGA monitor?
Hold the Fn key down again. (Bottom left of Keyboard)
Tap once more on the Display Toggle-Over key
NO display on the external VGA monitor, means you have a bad graphics chipset.
(By using an external VGA monitor, you are bypassing the Internal Display Switch, and the Display Assembly. (Internal monitor of laptop)
If you have a display on the external VGA monitor, you have a problem with;
1) Video Cable, (Display Panel Cable for HP)
or
2) Display Assembly
Post back with your results, and if you have a display on the external VGA monitor, we will go on.
If you do not have a display on the external VGA monitor, you are looking at motherboard replacement.
Regards,
joecoolvette
May 13, 2012 | HP Computers & Internet
Screen blank with white dot
Problem with;
1) Video cable:
A) Video cable connection on motherboard side is loose, and/or on back of LCD screen.
B) Video cable is damaged.
2) screen Inverter:
screen Inverter is bad.
3) LCD screen:
LCD screen is bad.
4) Graphics chipset:
Graphics chipset is bad.
Suggest you connect a VGA monitor to the VGA port (Connector) on your laptop.
See if the problem is the graphics chipset, Or video cable, Or display assembly.
You didn't state what manufacturer and Model Number of laptop this is.
All I can do is state generic information.
This is an example of a VGA Cable, and VGA connector,
The VGA connector will be on the side, or back of your laptop.
For the VGA monitor you can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
Laptop OFF, monitor OFF, connect the external VGA monitor to the laptop.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
There are at least 3 display options.
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
Press, and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(For an example HP's usually use the F4 key for a Display Toggle-Over key)
Display shows the same on the external VGA monitor?
You have a bad graphics chipset.
[ Some laptops have been erroneously stated as having a graphics card, when in fact they do not.
The GPU (Graphics Processing Unit) is soldered directly to the motherboard.
This is Integrated Graphics.
http://en.wikipedia.org/wiki/GPU
There is no changeable, replaceable graphics card. Therefore the solution is motherboard replacement ]
IF, the display is good on the external monitor, you have a problem with the Video Cable, and/or in the Display Assembly.
After diagnosing with an external VGA monitor, post back in a Comment.
Also post the manufacturer name, and model number of the laptop.
Regards,
joecoolvette
Apr 22, 2012 | Computers & Internet
Video on my toshiba L455=s5009 comes on for a few seconds then blacks out
From your brief diagnoses stated, it sounds like a bad Video Cable.
The Video Cable routes from the motherboard, across one edge of the Fan Assembly, and under the left Hinge assembly,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-Pro-L450-L455/big-body/laptop-disassembly-19.jpg
With just the usual opening, and closing of the laptop, the Video Cable's sheath may be damaged. This means the tiny wires inside the sheath may be damaged.
(Stretched/Broken)
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-Pro-L450-L455/laptop-disassembly-1.htm
http://www.laptoprepairparts.com/html/details.asp?ref=1860&category=cables
Or it may be the screen Inverter that is damaged, or going out,
http://mcccomputers.com/shop/lcd-inverters/3666-new-toshiba-satellite-l455-s5009-l455-s5045-lcd-inverter-pk070006t20-k000087330.html
Or the LCD screen assembly.
Could be the graphics chipset.
Diagnose.
1) Laptop OFF, monitor OFF, connect an external VGA monitor to the laptop's VGA connector, on the back of the laptop.
[ RBG (Monitor) port ]
You can use a CRT monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable, for the external VGA monitor.
[ Example of a VGA cable, and a VGA port (Connector),
http://en.wikipedia.org/wiki/VGA_connector ]
Turn the external VGA monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the external monitor should show the display, also.
IF not;
1) Press, and hold down on the Fn key, and simultaneously tap on the F5 key. (The F5 key is the Display toggle-over key)
Not showing on the external VGA monitor? Perform the above procedure again.
There are several display options.
External VGA monitor also show the same symptoms?
Bad graphics chipset. Replacing the motherboard is the most cost effective method, and easiest method.
External VGA monitor does Not show these symptoms?
Problem is the Video Cable, or screen Inverter, or LCD screen.
Due to movement of the LCD screen, which means movement of the Video Cable, my money is on a bad Video Cable.
(A Video Cable can be unplugged partially, real easy, on the back of the LCD screen.
It MAY look plugged in tightly, but may not be.
It can also be unplugged real easy when assembling the Display Assembly, to reinstall back on the laptop )
Check the Video Cable's wires with a multimeter. Perform a continuity check of all wires in the cable. (Multimeter set to Ohms)
Have an assistant also gently wiggle the cable, as you are testing. See if there is an intermittent break, due to a stretched/broken wire.
Or just buy a replacement Video Cable, and use it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 04, 2012 | Toshiba Satellite L455-S5009 laptop
What is needed to connect a laptop to my Vizio 42" LCD TV
What type of laptop (make/model) do you have? What video outputs are on the unit.
For most laptops, you need a VGA cable (assuming your laptop has a VGA port); the cable is sometimes labeled as a 15 pin D-Sub cable. If you want to use the TV speakers, you will also need a stereo 3.5 mm audio patch cable (male/male) . With both the TV and the laptop off, connect the VGA cable between the computer and the TV and put the patch cable from the audio out of the computer (speaker or headphone jack) to the VGA audio in on the TV. (The label is RGB PC for both jacks.) Then turn on the TV and then the laptop. (With some laptops, you may need to access the BIOS and enable the external video port. This is done by pressing the appropriate key repeatedly as soon as you start the computer. The key is Esc, F1, F2 or F10 depending on the brand of laptop.) Some laptops will automatically send the signal to an external monitor when it is present. On most though, you will need to set the display to the external monitor. This depends on the OS. Some laptops have a function key that does this. In Windows 7, you can do this by right clicking on the desktop (a spot with no icons or running programs) and choosing Graphics Properties. Then set how you want the display to run (external only, both screens or the laptop screen only). Please note that you may need to adjust the resolution for your graphics system. The best choices are 1920 x 1080 or 1360 x 768 at 60 Hz, depending on the laptop.
The GV42L does not correctly interpret an HDMI signal from a computer so do not use the HDMI port if your laptop has one. Also do not use a VGA to component video cable. If you have a laptop without a VGA port, you will need the correct adapter (DVI to VGA, for example).
I hope this helps.
Apr 14, 2011 | Vizio GV42L 42 in. LCD Television
Acer 5515 on external monitor
Get an VGA cable and connect your external monitor to your laptop via a VGA port that is usually used for digital projectors. In this VGA port, you can initiate dual monitors.
Then look at your keyboard and look an icon in your function keys (F1 to F12) that looks like a pair of an LCD and a TV like this {LCD icon/ TV icon}. In most laptop keyboards, this is located in F4.
When found, and with the external monitor hooked to the laptop via VGA port using a VGA cable, press and hold down the FN key and press the function key where the icons described above is located. Example, FN + F4 to toggle a single and a dual monitor.
Give it a try.
Jun 26, 2010 | Computers & Internet
Acer aspire 1500 no screen harddrive working software putting out correct start-up sounds
Try hooking the laptop up to an external monitor, use a vga cable. If the main display has died, the laptop may default a secondary if given the chance. If the laptop sounds like it boots but you can't see a screen on the external display try holding down the Fn key and at the same time tap the F5 key, this will toggle the display from internal to external. If a screen still cannot be seen then you may have lost the video processor on the motherboard.
Sep 06, 2009 | Acer Aspire 5100 Notebook
Philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Feb 10, 2009 | Philips 52 In. LCD HDTV
NEC Versa VX Notebook Logo
60 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
