Question about SanDisk ULTRA II 4GB Compact Flash Card Flash
I take pictures of white puppies on the same table in the same room.. some of the lighting is fine, some dark could it be the sandisk..??
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
Most likely it's the camera. Almost all cameras are designed to meter the scene as a medium gray. If you photograph white puppies in the snow, the camera will try to make the whole picture come out a medium gray, leading to gray puppies in gray snow. If you photograph black puppies in a coal bin, the camera will again try to make the whole picture come out a medium gray, leading to gray puppies in gray coal.
For this reason most cameras provide some means of adjusting the exposure. Since you didn't specify the make and model of your camera, I can't tell you exactly how to do it. Please look in the manual under "Exposure Compensation."
Posted on Jul 03, 2010
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
Pictures taken during the day are totally white, but the ones taken in dark rooms are fine
The exposures are set for low light and so the Camera is very sensitive. Please check the menu and set the mode to AUTO.
If this wont solve the battery can be removved ffor some time and replaced. If not there are errors in the control board.
Nov 01, 2010 | Olympus FE-310 Digital Camera
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
Images are coming out REALLY dark
first GET TO AUTO MODE WITH FULL AUTO
if this doesn't work try going to manual and setting the exposure up to +1 or +2
Feb 04, 2009 | Nikon D40x Digital Camera
Screaming static
Try turning off different lights near the room or in the room that it is in. Our tv does that if the overhead light in our bedroom is on, it's a room right next to our living room.
Jan 14, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
White lines when you take photos in light, but perfect in the dark
The problem lies in you camera's CCD unit which is located on the back of the lens held on be 3 small screws it could also be a setting in the camera's menu try going into the menu and reseting the camera to default it works some times if that does not work than you need the ccd replaced pretty easy fix I fixed 1 with the same problem about two weeks ago for someone it happens I hope this helps you out.
Jan 30, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Dark over night
Does the TV have a light sensor? If so, turn it off.
The light sensor limits the backlights intensity at night or when it's dark in your room in order for better vieweing convenience.
If you are in a dark environment, it really pains your eyes when the view is too bright. Same works the other way around. If it's day, and light in your room. The light sensor will dimm the backlight for it isn't needed.
Let me know if this solved your question.
Greetings,
DarkNeogen
Jan 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
No picture Just Sound
Hi
There are different possibilities in your case¸but what happened to me ...
The LCD Backligh is out , I mean the bulbs or neons of the screen BACKLIGH, you have to check either the lights itself or the driver circuit which supply the HV to operate it, usually its a separate small long PCB beside the TV main board .
You can try this trick , Keep all lights off in the room and bring a table lamp, preferred a white neon one and face it lighted on the top of the screen with the TV on , try watch a very dark but exact picture with the sound you are hearing. This is a way to be sure that it is LCD backlights problem when using an external light to illuminate the screen .
It worked for me ,Good luck
Nov 10, 2007 | Polaroid FLM-3201 Television
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
SanDisk ULTRA II 4GB Compact Flash Card Flash Logo
57 people viewed this question
Top SanDisk Cameras Experts
Henry
Nikki  Mclean
Nikki Mclean
Are you a SanDisk Camera Expert? Answer questions, earn points and help others
