The intake pushrod was broken in two
both pushrods were replaced
this is the second time the pushrods came loose
the valves open and close, but i think they are not in time
the gas supplly is ok
gas can be put into the carb
with zero compression no engine will start
A bent or broken pushrod is just a symptom of a larger problem that is causing a valve to hit the piston (or vice versa). Since you say the valves open and close, it's probably not a bent valve shaft, and like you suggest, it's the valve timing which is controlled by the camshaft gear. No matter what, it's not a repair to tackle at home. If the mower's in warranty, take it back for a proper repair -- and consider trying a different shop than last time. If it's out of warranty, you might find a small engine mechanic that can fix it for less than the price of a new motor. Get a good estimate before you say yes.
Removal & Installation
3.1L & 3.4L Engines
Left Side
To install:
To install:
