Question about GE JVM1540SMSS Microwave Oven
The light is out.
I never got a manual with this and I need to change the light bulb and I can't figure out how to open the thingy that houses the light bulb. Thanks.
    Brigadier General:
  • 4,088 Answers
Usually, you have to remove the outer case after pulling the power cord and wait for maybe 10 minutes to make sure the HV power supply has discharged itself. The lamp should be plainly visible at this point. Be sure to use the same wattage lamp as the original. Good luck!
Posted on Jul 02, 2010
Mco 153s can not find how to access oven light for replacement there does not appear to be access from above under filter no door solid metal only
On page 20 of your owner's manual:
To replace oven light:
1. Disconnect power at main fuse or circuit breaker or pull plug.
2. Remove the top grill by taking out the 2 screws that hold it in place. (See Figures 3.)
3. Remove charcoal filter.
4. Pull out the Lamp cover. (See Figure 4.)
5. Replace the light bulb with a 30-watt bulb.
6. Replace light housing to original position
7. Replace charcoal filter.
8. Replace top grill and secure with screws.
9. Connect electrical power.
Aug 10, 2013 | Magic Chef Over The Range Microwave
Can't figure out how to replace light bulb for model #721.66319
Sears Parts Direct lists the microwave, 72166319500 , as using the lamp, 6912W3B002L. This is available for $6.49 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Microwave-Parts/Model-72166319500/0582/0123245/50026833/00004?blt=06&prst=&shdMod= .
Unplug the microwave and wait a bit before starting to replace the bulb. To change the bulb, you first need to take off the entire cabinet (remove 4 screws on the back of the microwave and lift the part up). Then see the parts diagram on the page given above. There are 2 screws that hold the switch and bulb assembly to the frame of the microwave. I believe you should be able to pull the bulb housing down from the middle of the assembly and then push the unit up after replacing the old bulb with the new bulb. However, the bulb housing may have two screws holding it in place.
I hope this helps.
Nov 25, 2012 | Microwave Ovens
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Model # JVM1870W07-what is the easiest way to change these-was able to get the bulbs out-but can't the new ones in-hard to see the holes from the back
HELLO.The easiest and only solution is given below.
things you need
  • Phillips screwdriver
  • 40-watt replacement bulb
    1 Unplug the microwave and open the door.
2 Remove the screws from the front grill and pull it off of the oven. The screws are located on the underside of the grill.
3 Pull the light bulb housing toward you through the access panel.
4 Unscrew the old light bulb and replace it with the new 40-watt light bulb.
5 Rotate the light bulb housing toward the back of the oven. Reattach the grill with the screws and plug the microwave back into the electrical outlet.
Thanks.
Sep 16, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The light dows not work on my Sharo R254 microwave everything else is working. I gather all I need to do is change the light bulb but cannot find in the manual how to do it and what light bulb to...
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Mar 10, 2011 | Sharp R-254 Microwave Oven
How do you change the light bulb on an electrolux built in microwave ?
It is indeed straightforward but it requires removing the 4 phillips head screws that hold the trim kit on. Then you need to remove it from the cabinet (along with unplugging the cord.) Once that is done you will need to remove the 4 black phillips head screws along the bottom part of each side, 2 phillips from the left rear and 2 security T20 screws from the right side. I found that removing the 2 screws holding the bracket on the capacitor and the front allowed me to move the light housing enough to get to the bulb. In my case the bulb had unscrewed itself. I am not a big fan of the engineering associated with this model or the labor that assembled it.
Oct 23, 2010 | Electrolux Over-the-Range Microwave
Light Bulb Change
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Feb 01, 2009 | Samsung MD800SC Microwave Oven
How do I change the light bulb in this unit?
it has to be opened up to be able to change the bulb , but there is a dangerous high voltage capacitor that you should not touch as it still will hold a charge
Dec 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Ge profile spacemaker XL 1800 undercabnet microwave
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Sep 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Burned out light bulb
can u open the housing?. you can look at the spot where the light is and you can see a bulb holder screwed on the metal housing. it has two wires hooked up to that holder. remove those wires and unscrew the holder of the bulb. look closely at the bulb if it is fiited to the holder like an ordinary light bulb. if its like that then you can unscrew it and replace it. if its not screwed to the holder then you have to buy the whole bulb assembly at the dealer of your microwave. it is considered a special bulb only from the dealer you can get. i hope i was able to solve your problem..
Feb 18, 2008 | Microwave Ovens
GE JVM1540SMSS Microwave Oven Logo
57 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
