Question about Coleman Powermate Premium Plus 6250W Portable Generator
I have a Coleman Powermate pm0545007 generator with a B&S OHV model 200000 engine. It has always run fine, but after running it for about 3 hours last week, I can't start it. It has no spark. I replaced the spark plug, but still no spark. Oil level is ok (filled to top of plug). I checked wiring and found black wire that runs from on/off switch to engine is crimped between metal frame that connects engine to the generator frame. This looks like it make cause a short. Should this be crimped in the frame, or should it hang loose? Also, I'd like to bypass the low oil switch. There's a black wire from the low oil switch and a white wire from the on/off switch that connect to a sealed electrical device on the motor frame. How do I bypass the low oil switch?
  • jbart60 Jul 11, 2010
    Thanks for the reply. The problem turned out to be the crimped wires. I ended up cutting the wires on either side of the crimp and splicing them together. The engine started on the first pull.
    Problem Solver:
  • 12 Answers
There should not be pinched wires...
if you mean "how do I bypass the low oil SENSOR" then the answer is to just disconnect it and tape up the end or snip it off in a location where it won't ground out...the way these engines kill the spark is by grounding the cdi coil wire...so fix that pinched wire and youre probably good to go...dont disconnect the low oil sensor unless its causing trouble....having low oil protection is good and might save you from blowing an engine
Posted on Jul 03, 2010
Hi i have a Black max, Powermate Generator model #PM0496750 ,6750 watt it run great for 3 hrs and then stop generating,,, clean the frets on rotor where brushes runs on and its good for another 3 hrs then...
You have excessive arching on the rotor slip rings by the sound of it, if you clean them and it works well then 3 hours later same problem? What is the conditon of the brushes? Also I trust youa r enot cleaning polishing them with sanpaper etc, they have a very fine finish and should be polished with a super fine grit paper or stone, pref while turning the engine. Any scratches won't work
Oct 05, 2013 | Coleman Powermate Powermate 5000W...
Coleman Powermate PM0545007 generator. Unit started and ran. I turned on a window air unit and it worked ok then in about a minute the generator shut off. We are in a hurricane, so I'm trying to...
The generator has a low oil level sensor. Fill the oil all the way to the FULL mark and try it again.
IF you still have the problem after adding oil; repsond here and I can still help you. Just want to get this off as it has been 4 hours since your post.
Kelly
Aug 28, 2011 | Coleman Powermate Premium Plus 6250W...
Have a coleman powermate 6250 model #pm0545007,won't start,what to look for?
Fresh Fuel
Clean carburetor if stored with fuel in the tank and wasn't shut off
Clean fuel filter
Clean air filter
Proper oil level
Clean spark plug (just replace it, it is easier and faster)
May 20, 2010 | Coleman Powermate Premium Plus 6250W...
Tecumseh model 100 engine 10hp on a coleman powermate generator it starts ok however after about 3 minutes the engine sputters like it is running out of gas and quits.
check the fuel mixture settings i believe main screw is 1 3/4 turns from closed and the idle screw is set at 1 1/4 turns from closed. These settings are for non OHV models. also check that if you have a fuel filter installed that it is not plugged up.
Sep 27, 2009 | Coleman Electrical Supplies
Coleman powermate pm0545007,ran out of gas, refilled, never so much as cough. won't start
How old is it hand about how many hours on the unit. Does it have a Briggs engine?
Sep 20, 2009 | Coleman Powermate Premium Plus 6250W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Looking for a Pricesheet
google"coleman powermate". on the site look for manuals. the price list is the top manual. kinda small. you may have to increase magnification. mike
Nov 17, 2008 | Coleman Powermate Premium Plus 6250W...
Not a 6250W but a 6500W Coleman Powermate Black Max.
Call Pramac Co. at 770-218-5430. I get parts from them every week. A service center left holding the bag when Coleman/Powermate went out. Ken's Repair
Sep 15, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
942 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
