Question about Dometic Rooftop RV Air Conditioner
I have a 13500 penguin ducted AC on a 2007 24 foot Bigfoot Class C motorhome with thermopane windows. I had it parked and had the ac set at 90F since I was working in and out of motorhome. I had put alum foil bubble wrap on all windows skylites ceiling hatches. I am at location where the outside day temp is about 116f and lowest night temp is 85f. Since I got his motorhome used. I set the thermostate to 65F and took readings at outlet of furthest duct was 65F, reading at the cooldown outlet is 58F. I even put alum bubble wrap between the coach part and the cab, looks ugly but insulated. the inside of motorhome is about 80F after running this arrangement for about four hours. I am wondering if AC is OK or if I should upgrade to 15000. Or am I asking too much.
  • 3,083 Answers
Of course, upgrading to the 15000 would cool you more, and more efficiently. You're pushing the limits of the 13.5 k unit, but it's your comfort that matters. If it's sufficient for you, that's probably the bottom line. Not sure what your top temperature outside will be, and that will determine if you need to upgrade or not, but it seems to me that it's holding ok, under the circumstances. Your comfort- and your call!
Posted on Jul 03, 2010
  • William Gehrke Jul 03, 2010
    Is the differentail temp. outside of 116F to the Temp. at cooldown outlet 58F (this is the closet outlet) acceptable for a 13500 unit. I forgotoe mention that the compressorseems sort of loud,
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Dometer 3105457. how big of generator for the air
If it is a normal AC for RV then I would suggest something over 4000 watts, the AC's have a very high start amps.
You would really need to know how many amps the unit draws or is rated to draw when looking for a generator. Too small of a generator and it won't work, plus you could damage the generator and the AC unit. I would call an RV store and ask them as that is something simple for them to answer.
600315 336 Manuals
Jun 17, 2014 | Dometic 3105457.000 Duo-Therm Penguin RV...
I have a new motorhome and the air conditioner only reduces the inside air temperature by 2 degrees on a hot day. e.g. outside air temp 26 degrees inside temp 29 degrees. After 2 hours of a/c running with...
Can you tell me what size/make of motorhome you have? Certainly doesn"t sound right to me, and I've been working on them for over 15yrs. Whether it's a 13,500 BTU or 15,000 BTU, it should be plenty as long as motorhome has any insulation at all. I assume you have central air from ceiling?
The manufacturer usually states that the AC unit will supply 20F below ambient.
Is compressor staying engaged all this time?
May 22, 2011 | Dometic Rooftop RV Air Conditioner
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
Mar 11, 2010 | Dometic Rooftop RV Air Conditioner
9,200 btu Coleman AC in winnebego era cannot adequatly cool coach. Can I install a 13,500 btu without any modifcations to the electric
As I understand your question, you want to replace your 9200 BTU air conditioner with a 13500 BTU.
If this was all there was to it, I'd say no problem, but I would be doing you a disservice. I work in a camping resort and I encounter troubles with guest's AC all the time. And this may not apply to you ... but here is the problem I see. Many coaches come into our park loaded with equipment from the manufacturer and the owners pile on more. Many are equipped with a 30 amp service. Thirty amps of power is one TV, one Microwave and incidentals - OR - One TV, one A/C and incidentals. I'm my experience, it is pushing the envelope to try to run a TV, AC and Microwave and incidentals, 30 amps will simply not support this load.
If yours is a 50 amp service, you probably will not have this trouble.
If your AC is on a dedicated branch circuit in your coach, it is probably a 15 amp. A 13500 BTU unit should also run on a 15 amp circuit.
When my wife and I encountered the inadequate AC problem you describe, we made the coach "smaller". We closed off the bedroom and bathroom and the AC was able to make us comfortable on those few very hot days.
I appreciate the opportunity to address your concern and I hope my response is helpful for you.
Thank you for posting your question at FixYa.com
Please vote. It is important to us volunteers
Thank you
a
Nov 10, 2009 | Cell Phones
Duo Therm Penguin model 610115.311 AC unit no-power
Actually you should have fried you converter. What is the voltage reading you get for the air conitioner? supply? One should run off the generator and the other on shore powerIs it set up that way?.
Sep 28, 2009 | Heating & Cooling
Penguin 13500 ac short cycling
UNITS THEMOSTAT IS BAD REPLACE THERMOSTAT IF DONT SOLVE PROBLEM MAKE SURE UNIT IS NOT FREEZING UP AND BOUNCING OFF A "FREEZE STAT" CASING COMPRESSOR TO SHORT CYCLE
Jul 31, 2009 | Dometic Rooftop RV Air Conditioner
I have a 13500 Dometic roof mounted ducted AC on my motorhome. I have changed the Board twice and the thermostat once and the same problem occures. When you first put the AC on it works fine until it goes...
May need start capacitor and relay (called start kit) or some of the compressors have a thermal overload under the compressor cap. If it's a thermal overload, it has a bimetal disc and when it reaches a set temperature (hot) the disc will warp opening the compressor circuit and not allowing the compressor to come on till it has cooled down. if this is the case then the compressor is not getting enough refrigerant back to it to keep it cool or it's drawing high amps.
Feb 24, 2009 | Heating & Cooling
Penguin Duo therm AC bogs
Try replacing the wall thermostat with an electronic unit. It sounds like it is short cycling. If there is not at least 5 min delay before trying to restart the compressor this is what happens. Most electronic thermostats have a delay feature built in to solve this problem.
Jul 08, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
37 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
