Question about Bosch Axxis WFL 2060 Front Load Washer
Replaced the control pannel and now washer won't spin. Why?
We have a 2004 Bosch washing Machine the control pannel went out so we ordered the part and replaced it now it will wash the clothes but it will not spin them dry. The panel has spots for the leads to go into but they will only fit one way. Is there something we are missing?
  • 1 more comment
  • tsoliver Jul 03, 2010
    Yes we do want help. How fast can we get the info on how to configure the control panel and how much will it cost us?
  • tsoliver Jul 04, 2010
    my address is touchingcloth@hotmail.com thank you
  • tsoliver Jul 05, 2010
    I am so sorry my husband gave me the wrong email address it is Touchingcloth@live.com can you send it again? Please and thank you
  • Bosch Master
  • 2,605 Answers
Hi welcome to Fixya. The issue with simply replacing those controls is that they do not come configured. This must be done before installing and operating the control. It cannot be done once installed and continuous attempts to use it could cause damage to the control. I can send you a guide on "how to" but I'm presently out and do not access since I'm using my iphone. I'm currently in the process of setting up a windows live account that will allow people to access these things much easier, but I'm not there yet. Stay tuned ha ha ! Let me know if you'd like further assistance. macmarkus :)
Posted on Jul 03, 2010
  • 3 more comments
  • Mark MacDonald
    Mark MacDonald Jul 04, 2010
    I will check and see if I can access my files when I get back to my netbook in about an hour, failing that I can send them tomorrow evening when I get home. Either way I would need you to post an email address as they are in "pdf".
    Macmarkus :)
  • Mark MacDonald
    Thanks for providing the address, I will have to send you the file when I get home later this evening via the email address as I don't have the file on my netbook or iphone.
    macmarkus :)
  • Mark MacDonald
    Mark MacDonald Jul 05, 2010
    "pdf" has been sent.
    Good luck.
    macmarkus :)
  • Mark MacDonald
    Hello again,
    just re-sent "pdf" to Touchingcloth@live.com.
    Let me know when you receive it either via post here or email, thanks.
    macmarkus :)
  • Mark MacDonald
    Mark MacDonald Jul 06, 2010
    I also sent you via email attachments for a WFMC6400 since it turns out that is the model we are dealing with. For the record anyone referring to this post, these control modules ( unlike the WFL, WFR, etc. ) are configured from factory for replacement and DO NOT require programming/set-up or switching in anyway. They CAN however be installed with the dial 180 degrees off or mis-wired...it's possible, espeicially in relation to the heater/NTC which in turn can prevent proper function or provoke an E:05 error code.
    Please reply when possible.
    macmarkus :)
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Bosch Washer WFK2401UC/01 Does not spin. Replaced Power cir. Bd. Turned on started right up. completed cycle. Went to wash this morning Drum will not spin
Sometimes the brushes on the motor get worn and they cause motor to act intermittently. I changed my brushes and this corrected the problem of not washing or spinning.
Dec 11, 2014 | Bosch Washing Machines
Brand-new Bosch Axxis washer not working (3 lights on the control panel blinking together)
It has at least a year warranty don't mess with it call the seller. Manual should have error codes.
Dec 18, 2017 | Washing Machines
My Bosch next 300 washer doesn't spin as fast as it did. It leaves the clothes wet and some water in the drum. No error code comes up? How do we fix it?
If the tub still moves but it's just not spinning that fast (and the water is draining out), then that means your motor control board has just started to fail and it will need to be ordered and replaced to fix the issue. If you pull the washer out and remove the back panel, there is a control board mounted to the floor under the tub. This is the motor control board and it will need to be ordered and replaced to fix the issue.
Oct 28, 2012 | Bosch Nexxt 300 Series WFMC2201UC
I have a 2009 bosch 100 series washer that won't wash or spin, but will drain?
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Mar 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
The machine won't pump water or spin and makes nasty noise. When I turn the drum by hand there is no noise and feels normal.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 08, 2011 | Bosch Washing Machines
Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
Aug 16, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Rinse and spin
there is a safety switch on the top...and when you close the lid it pushes down on that switch. investigate that switch and see if its just corroded or needs replacement...i have that same problem when i leave the lid open on my washer...then it works fine when i close it...so im figuring that your's thinks its still open. I hope this helps you out ! and give your wife a hug 8-)
Jun 05, 2009 | Washing Machines
Bosch WFR 2460 washing machine
the pum should do that but the magnet side may have saturated with water beyond the seal. i recommend replacing the pump.
Mar 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
180 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
