Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
How to program a phone number into the phone - Uniden DECT 6.0 Cordless Telephone Expansion Handset
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
What model Uniden DECT 6.0 system?
Posted on Nov 26, 2013
I want to reprogram some numbers on AT&T 822 (21213)
1. Lift receiver, touch "program" (above number keypad, on the bottom left of programmed numbers).
2. Enter phone number (1-AC-Number).Touch button for quick dial station (e.g., Name of Person to Call).
3. Hang up phone.
4, Lift and touch programmed button to dial (new) number.
Oct 06, 2013 | Lucent AT&T Speakerphone 822 (21213)
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    Hi I have a panasonic KX-T433 phone system which I am trying to put in speed dial numbers, we have to dial 9 to dial out does any one know how to do this using a 9 in front?
    You have neither a 7730 (the category you asked in) or a 7433 phone sytem. If your phone is really a 7433, you have a TD phone system. Which "speed dial numbers" are you trying to program? System speed dials, are stored in system program 001 and consist of a 3 digit number (may be 2) with a "9" in front and the number as you would dial it from the keypad. Personal speed dial numbers depend on the button you're programming it onto. If it's a button with a light, you dial "2" in front of it. If not, you don't. So, Program 99, button, and either 29 + number STORE or 9+number STORE programs a personal speed dial.
    There are other programs to store under the tone pad keys. Those features are covered in your User's manual for the TD system.
    Carl
    Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
    How do I manually enter phone numbers into the "speed dial" directory of my Toshiba FD-9859 cordless telephone?
    Welcome to Fixya
    To program a speed dial on your phone, enter programming mode (press #9876 on your phone). The phone will display "USER PROGRAMMING MODE." Press the Spdial button, enter a speed dial number (100-119), 9 plus the phone number you wish to dialed (1-213-555-1212 for example), then press the Spdial button one more time to lock it in. To use a programmed speed dial, just press the Spdial button plus the number.
    Thank you for using Fixya!
    Apr 06, 2011 | Cell Phones
    I have panasonic kx-t7730. How to set the intercom name and number?
    Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
    It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
    Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
    Programing Speed dial on Walker W1000 Clarity Phones
    I solved my problem by trial and error!
    Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
    1. Choose phone number to program including the (#1) digit for a long distance direct dial if
    needed.
    Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
    names or contact description (ie."Mom's Cell Phone.")
    2. Remove hand set receiver from phone.
    3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
    4. Enter phone number chosen,including area codes and long distance prefixes if needed!
    5. Locate the speed dial position button you want for that number...(located adjacent to
    tag/pad slot for name and/or phone number to be written after entering.
    6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
    7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
    correct phone number is contacted. Once established as correct; program additional speed dial
    numbers: ie family, business, as needed.
    8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
    own memory!
    9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
    again in the procedure sequence.
    10. Remove white "description pad with slots for names or numbers) from underneath clear
    plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
    on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
    11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
    ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
    BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
    NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
    USE this procedure to see if you program correctly then once you know how; go back and re-
    enter all the numbers that you actually want on your speed dial settings.
    Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
    Programmed numbers
    Feature 00
    Press button to program
    enter intercom+number to dial
    Feature 00
    Aug 22, 2008 | Lucent PARTNER18 Corded Phone
    Changing numbers?
    To program the personal directory Its diferent to program the system directory. the personal has 8 number capaciti and the system has 999 number. To program the System directory
    1.- Enter to PBX program mode from your station 101
    2.- Choose program 001 to enter the quick dial numbers
    3.- Choose program 002 to enter (Or change ) the Labels
    Jul 05, 2008 | Panasonic KX-T7630 Corded Phone
    Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
    18 people viewed this question
    Top Uniden Lands Phones Experts
    Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
