Question about Heavy Duty Grinders
Westinghouse ac motor #S1179100-C type-FJ has 4 wires marked T-2,T-3,T-4, AND 5 How to wire it up? Its a single phase 115v. half hp.
  • 1388 Answers
SOURCE: rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Posted on Dec 14, 2008
erpaalai
  • 999 Answers
SOURCE: wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Posted on Jun 17, 2009
EMSRSERVICEG
  • 426 Answers
SOURCE: 3 phase 2 speed brake motor diagram
YOU CAN CALL THE MAKER OF THE MOTOR
Posted on Jan 12, 2010
thepool
  • 78 Answers
SOURCE: need wiring diagram for a marathon electric motor
Wiring diagrams for AO Smith motors are located on the side of the motor.
Posted on Apr 21, 2010
SOURCE: i have a doerr electric motor, lr22132 single
i have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great,
Posted on Oct 03, 2010
Can i get a wiring diagram for a westinghouse type FJ motor. it has a B145 frame; 1 phase; 110 v; westinghouse part #NO-1008
because it is 110 volts any work by yourself will be dangerous. take it to an accredited electrical motor rewinder for what you want and be safe.
Mar 06, 2015 | Miscellaneous
Tip
How to Reverse the Rotation of Single Phase Capacitor-Start Electric Motors
Reversing the rotation of electric motors can be done easily with 3-phase motors. This can be easily achieved by swapping the connection of any two motor leads. But 3-phase motors are usually found and used for industrial purposes. The ones found and used in our homes, from water pumps to electric fans, are single phase capacitor-start type motors. Unlike 3-phase motors, reversing the rotation of single phase electric motors is no easy task. Swapping any two motor leads will not result in the reversal of the motor rotation. Analysis of the motor windings and connections are necessary before any modification can be done to achieve the desired result. Let's take a 3-speed single phase capacitor-start electric motor with electrical diagram shown below as an example. Make sure the motor is disconnected from the power supply before attempting to follow this tip. This tip is intended only for individuals with electrical knowledge, necessary tools, and understand the risks associated with handling electrical equipments and devices.
The first step in the process is determining the start winding which is connected to the line (AC white) and to one side of the start capacitor. To accurately determine the start winding, disconnect all motor leads from the start capacitor and the speed switch for multi-speed motors and then setting your ohmmeter to the lowest scale (R x 1), measure the resistances between the AC white line and each of the motor leads connecting to the start capacitor. The one with the least resistance is the starting winding lead.
Once the start winding lead going to the capacitor is determined, reconnect the capacitor then connect the black AC line to the found start winding lead (marked X). Connect the white AC line to L of speed switch, the motor lead formerly connected to AC white to 3, red to 2, and white to 1 as shown below. Leave the green/yellow ground wire connection as is.
Below are the wiring modifications for 2-speed and single speed single phase capacitor-start electric motors.
on Jan 11, 2011 | Dryers
What is a DIVERSITECH BLOWER MOTOR WG840587 wiring
Have a look to following link:
http://www.diversitech.com/Product?id=01t80000002s8rGAAQ
and:
This must be a 115V AC single phase motor.
That means you have to connect it to your normal power supply system, 3 wires, 1. phase, 2. zero, 3. protected earth. That's all.
Sep 01, 2014 | Heating & Cooling
Old motor wires are numbered new motor wires are colored this is a 1/2 hp reversing motor for a overhead door
Single Phase Terminal Markings Identified By Color: (NEMA Standards) 1-Blue 5-Black P1-No color assigned 2-White 6-No color assigned P2-Brown 3-Orange 7-No color assigned 4-Yellow 8-Red
Mar 02, 2014 | Computers & Internet
SINGLE PHASE WIRING DIGRAM
You need a single phase motor to do that. A 3 phase motor cannot be made to run on one phase.
May 16, 2013 | Ingersoll Rand - Rand Type - 30...
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
How do I connect multiple (two or more) 3 phase ac power sources (from wind turbine alternators) to a single 3 phase junction to power one device?
what did you mean by single 3 phase? single phase motor have two wire output 110-110, 3 phase gen have 3 wires 110-110-110. if only two wires here ,this is single phase, all appliances are only single phase so you can connect it here, except some 3 phase motor or dynamo. the ac current has no polarity so you can connect to it all kinds of load depends upon the amperage of of your turbine generators
Jul 22, 2010 | Kitchen Ranges
How to wire a 3 phace 5 hp baldor motor
the neutral or white is not used. if the fourth wire is a ground then it goes to the motor frame. if it is a dual voltage motor then here is the wiring: for 240 volt 3 phase connect 4-5-6 together and tape, 3-9 goes on L1, 2-8 together goes on L2, 1-7 together goes on L3. To reverse direction swap any two line wires. For 480 volts 3 phase: L1 goes on T1, L2 goes on T2, L3 goes on T3. Connect together T6-T9 and tape, connect T5-T8 and tape, connect T4-T7 and tape. again to reverse direction swap two line wires.
Oct 14, 2009 | Baldor 115v,1ph, 3,600rpm 7" 1/2hpbnch...
I have 1 black, 1 white and 1 green ground on pressure switch. ?
Black & White would both be 115v on a single phase 230 circuit, green would be ground.
Jul 20, 2009 | Ingersoll Rand - Rand Type - 30...
Wiring a 220v single phase motor and capacitor
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Grinders Logo
653 people viewed this question
Top Heavy Duty Grinders Experts
DrBogo
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Heavy Duty Grinder Expert? Answer questions, earn points and help others
