Question about Westinghouse LCM-19v1 Monitor
Monitor flashes on when I turn computer on, then screen black
Yesterday I came back to a black screen monitor after it had been working fine. It flashes back on for a second every now and then when I either turn the computer off and on or turn the monitor off and on. It also make a "crackling" sound as it goes black.
My husband looked at the video card and it looked clean. I also checked the connections. Any suggestions? I need to get my Ebay items out today! Murphy's law I guess.
  • 1 more comment
  • Anonymous Jul 02, 2008
    My computer flashes a normal screen then turns black?
  • Anonymous Oct 16, 2008
    My monitor did not recover from hibernation. I turned off computer and unplugged monitor and computer and tried to reboot. I could see parts of the boot up screens for a second as they flashed by but then nothing. Power light is on. I connected my computer to an old monitor and all works well. What's wrong and can it be fixed?
  • marthaam Jan 27, 2009
    My monitor started to make a sound like a fan and then goes to black, does anyone now how can i fix it?
    Problem Solver:
  • 6 Answers
Your monitor power supply or inverter board have gone bad. Its not your computer video card
Posted on Apr 20, 2008
I have a Gateway Laptop and a ViewSonic monitor and relocated them into my office yesterday. The ViewSonic was working fine. When I booted everything back up the Viewsonic turns on, flashes my...
It means that there is no video signal from your video card. 1. Check the video cables 2. Try connecting your internal video card if you have one or change the card with new one.
Feb 28, 2011 | ViewSonic VX1935wm LCD Monitor
Working fine till yesterday. When shutdown
Open up the set and look for bad caps, see some failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Gateway FPD1760 Monitor
Monitor goes black
I also have a hp w1907 monitor which also powered on for a second and then go blank with the power light still on.. it was out of warranty so I had no loss so I took it apart..I found one of the wires broken at one of the backlight bulbs { becarefull they are fragile and there is four of them, two on the top and two on the bottom... and the lcd screen is very fragile } I soldered the wire back on and it all work fine... just remember where all the screen parts go.
Oct 24, 2009 | HP w1907 LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Computer screen is flashing
dell monitor will work fine and then go black with an internal blue light flashing from the bottom of the screen up. I have checked wires they are ok. I am able to get it working sometimes if I move the position of the screen back and forth or up and down the on button will stop flickering and it will come back on. HELP!
Jun 24, 2009 | HP f2105 21" LCD Monitor
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor Flashes Gray, Then nothing
try to decrease the screen resolution. try to 640 x 480 then raise to 800 x 600. for old CRT monitor maybe have a problem with 1024 x 768. if decrease not work, then you might have a hardware problem, you need to purchase a new one. try the test first. maybe you can test with your monitor of your friends first :-), if work, you need to purchase a new one.
Feb 17, 2008 | Acer AL1916W 19" LCD Monitor
Westinghouse LCM-19v1 Monitor Logo
1,084 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
