Question about Ricoh 2050L Laser Fax
I have a fax number and the international code. How do I input this information to fax overseas?
    President:
  • 3,085 Answers
Exactly the same as you would dial it on a telephone
Posted on Jul 03, 2010
CLX-3185FW I would like to know how to send a fax overseas. Where do I put the paper to be send? Thanks
You are talking about a Samsung all in one printer model CLX3185 and not a PDA right? You can put the document that you want to fax into the automatic feeder on the top of the printer or directly on top of the glass - your choice. If you use the auto feeder on top of the printer, look for a picture of paper near the insertion point that shows you whether the text side goes down or up when you put the paper in. If using the glass on the flat bed, the text goes down.
Once the document is loaded in either place, push the button that says "fax" and enter the number with the Country Code first and then press start. The line you are using to fax should have international calling enabled in order for this to go overseas.
Sep 14, 2011 | RIM Computers & Internet
HOW TO SEND FAX INTERNATIONALLY
Sending a fax to another county is easy - almost as easy as sending a fax to someone in your own country. The only difference is the phone number that you'll dial.
When sending a fax from one U.S. city to another, you dial a 1, then the area code, then the seven-digit phone number. When sending a fax from the U.S. to another country, you usually dial 011, then the country code, then a city code (which is like an area code), then the phone number. (The phone number isn't necessarily seven digits.) Check out the web site www.HowToCall.info, which will give you the specific country and city codes for the place that you're trying to send a fax to.
Other than figuring out the phone number, faxing internationally is identical to faxing domestically. Fax machines in other countries use the same protocols as ones in the United States, so you should have no difficulty communicating with a foreign fax machine. Older fax machines and noisy overseas phone lines may cause the transmission to take a bit longer than you're used to, but it should get there.
The first time you send a fax to another country, it might be a good idea to listen in as the fax machine dials. On some fax machines, you can press the "Dial" button to hear the dial tone, and dial the number manually. Listen for the ring and fax tone, then press the Start button to send the fax. You might want to do this the first time you send a fax overseas, just to make sure it's working as expected.
Oct 06, 2010 | Office Equipment & Supplies
My machine will not fax overseas
Hello.
Be certain that you use the code for international calling, that your FAX line can support international calls / faxes and that you have selected Overseas Mode.
Hope this helps.
Mar 27, 2010 | Brother IntelliFAX 2800 Laser Fax
Trying to send a international fax
press the MONITOR key then dial your number this will allow you to use your machine as a speaker phone to hear the dial process, it will be slower but will work.
Oct 20, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
How do I add the "+" sign to send an overseas tax?
There should be no need to get the (+) sign. Dialing 011 + country code + phone number should allow you to directly call the fax you're trying to reach. This link will explain the process as well as supply country codes. I hope this solves your problem. Best of luck to you.
http://www.q7c.com/travel/telephone.htm
May 09, 2009 | Office Equipment & Supplies
Need to send an overseas fax - how do I get the "+" sign before the fax no?
I don't know what you mean about a "+" sign. There is no sign necessary. For example: You can't do it on a regular telephone call either.
If you're having trouble figuring out the dialing codes, this link may help:
http://www.timeanddate.com/worldclock/dialing.html
Calling overseas from Australia to UK on a Uniden 9035 handset
Just dial 0011 then the country code. The + is just a quick way of dialing 0011.
Also these can be used from Australia 0011 (Voice calls)
0015 (Fax calls - Telstra)
0018 (Telstra special rates)
0019 (Fax calls - Singtel Optus)
go to http://www.kropla.com/dialcode.htm full a full list of international codes
Dec 01, 2008 | Uniden Cordless Phone
Sending an international fax with a brother fax machine
I'm thinking you did not specify 1 for long distance and international calling check the TX settings for international and long distance
Aug 23, 2008 | Brother Office Equipment & Supplies
Faxing
Call the operator to find out the country code and the city code. I believe the overseas access code for Canada is 011, but you'll have to check with the operator
Feb 20, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Sending a fax from my L80 to an overseas fax machine.
overseas calls must use 011 then the country code 866 then teh city code then the fax number . Do not dial starting with a 1 otherwise you will be calling in North America
Sep 03, 2007 | Canon FAXPHONE L80 Laser
Ricoh 2050L Laser Fax Logo
94 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
