It is a nw kyboard but I cannot gt som kys to work. It is a Microsoft board
  • aore Jul 09, 2010
    Great help Thank you
  • aore Jul 09, 2010
  • 493 Answers
Hİ,
You may fins some information on this microsoft support page related to your microsoft keyboard problem.
Hope this helps.
Kind Regards.
Posted on Jul 02, 2010
  • 5 more comments
  • aore Jul 02, 2010
    Thanks,
    I have cleaned the keyboard as suggested but still not operating.
    I live on an isolated tropical island so manufactured warrenty is not important.
    Can I take the keyboard apart at the back and clean the keys?
    Any tips?
    Thnaks Anne
  • Ibrahim OKTAY
    Ibrahim OKTAY Jul 03, 2010
    Hi Aore,
    Of course you can clean it. You may check this link before cleaning your keyboard for tips. And here is thr tips how to remove a key from your keyboard.
    Best wishes.
  • Ibrahim OKTAY
    What is the model of your Microsoft keyboard. This link and this link may be helpful to disassemble the keyboard.
  • aore Jul 03, 2010
    Thanks, the info really helps.
    Is there any other reason a key can stop working, it is only the f, e and k keys, I thoight it may be locked for a purpose. You can tell I am a computer dummy.
    Thanks heaps,
    Anne
  • Ibrahim OKTAY
    Hi Anne,
    The BIOS checks the keyboard when it starts. When you boot do all three lights on the keyboard flash such as the CAP Lock, NUM Lock, SCROLL Lock ?
    Please try to restart the PC and enter the BIOS by pressing "Del" or "F2" key (or it may be a different key for your PC).
    Then set the BIOS to default and save, exit. Restart PC.
    If it is set to default the error reporting will be on. There is usually a setting by Default that says: "STOP on error: Press F1 to continue". If this is OFF then the error would not be reported and also pressing F1, if functional, would simply load with the error.
    Then open a notepad or word document.
    Try the keys if they are working or not.
    If not you can try to update the BIOS.
    Waiting your comments.
  • Ibrahim OKTAY
    - And check your keyboard with another PC.
    - Check your settings under Control Panel | Regional and Language settings |
    Keyboards
    - Test your keyboard in the Windows Safe Mode.
  • Ibrahim OKTAY
    - Go to device manager and uninstall the keyboard drivers. restart the PC. windows should load new drivers.
    - Look in control panel/add remove software for keyboard controlling software if there is any.
Netflix error 405
http://forums.mozillazine.org/viewtopic.php?f=38&t=605984&p=3155060
http://www.checkupdown.com/status/E405.html
SYMPTOMS
When you browse the default document, you receive one of the following error messages: HTTP Error
405 Method Not Allowed
The method specified in the Request Line is not allowed for the resource identified by the request. Please ensure that you have the proper MIME type set up for the resource you are requesting.
Please contact the server's administrator if this problem persists.
HTTP 405 - Resource not allowed
Internet Information Services
This problem occurs if the following conditions are true:
  • You do not specify the file name. For example, you do not specify http://Server/Web/.
  • The Scripting Object Model (SOM) is enabled.
  • A DTC event is called.
CAUSE
This problem occurs only when you use Microsoft Internet Information Services (IIS) 4.0 and Microsoft Internet Information Services 5.0. This problem occurs if you send a POST request to a server that is running IIS 4.0 or IIS 5.0, and the POST request contains a URL that ends in a slash mark (/). IIS returns the 405 error message instead of the default document. However, if the method value of the Verb property is GET or HEAD, IIS returns the default document. RESOLUTION
When the SOM is enabled and a DTC event is called
When the SOM is enabled for the page, a <FORM> tag that is similar to the following is inserted in the page. <FORM name=thisForm METHOD=post>
Because no ACTION attribute is specified in the tag, both Netscape Navigator and Internet Explorer try to make an HTTP POST request to the URI "web/". According to the HTTP RFC (RFC 2068), this is not a valid Request-URI for a POST operation.
To work around this problem, use one of the following methods:
  • Redirect from the default document to a different document. In this case, the SOM-enabled document will no longer be the default document. The new default document will just redirect to the SOM-enabled document. For example, if your SOM-enabled document is named MyDefault.asp, the default document (Default.asp) will contain only the following code. <% Response.Redirect "mydefault.asp" %>
  • Use client-side script to make sure that the file name is included in the URL. If you must use your SOM-enabled document as the default document, use a client-side code block that is similar to the following code block as the first code block within the <HEAD> section of the page. This code block does the following location replacement. Language=JavaScript> var loc = document.location.toString() var loclen = loc.length //The name of the default document var filename = "default.asp" var filelen = filename.length loc = loc.substring(loclen - filelen, loclen) if (loc.toUpperCase() != filename.toUpperCase()) { location.replace(filename) }
When the remote scripting is called
This problem may occur if you use the window.location.href property in an HTML document to determine the path of the current document. If you do this when you initiate a remote scripting call, the remote scripting call fails because the client page does not have a file name.
To determine whether the page can use remote scripting on the client, verify that the value of the window.location.href property does not end in a slash mark. To provide a file name in the client browser, and to prevent the error on the server, use the Response.Redirect method redirect the request from the default page to another page. For more information, see the first resolution method in the "When the SOM is enabled and a DTC event is called" section. STATUS
Microsoft has confirmed that this is a bug in the Microsoft products that are listed in the "Applies to" section.
This bug was corrected in Microsoft Internet Information Services 6.0. Properties Article ID: 216493 - Last Review: 11/21/2006 13:13:42 - Revision: 3.2
Applies to
  • Microsoft Internet Information Services 5.0
  • Microsoft Internet Information Server 4.0
Keywords:
  • kbbug kbctrl KB216493
Apr 20, 2014 | Netflix Computers & Internet
Prosim vas zmazala som vsetky udaje z mojho walkmenu a ukazuje mi no data ako mam postupovat nejdu mi tam ziadne skladby
http://esupport.sony.com/US/p/model-home.pl?mdl=NWE105&LOC=3&session_id=0d482ec45e9a3262aac683a96be3ff18#/howtoTab
Aug 10, 2011 | Sony Network Walkman NW-E105
My keyboard and mouse are not working. 3 days ago when I last used my computer everything was working fine, however today when I tried to start it up I could not type in my password and the lights on my...
You have to log in to windows to fix this problem by borrowing a wired keyboard to enter your password. After log on go to Start-> all programs -> accessories -> system tools -> system restore and restore your computer to 3-4 days ago when it worked ok.
Jan 16, 2011 | HP P2360AA Keyboard/Mouse
Window vista product kys
Contact Microsoft or the company you purchased Windows from.
Dec 06, 2010 | Microsoft Windows Vista Ultimate Edition
How do I get the sound to work again on my Compaq laptop? For som reason it is not working
we need to reinstall it from device manager... comp>>> properties>>>> from the page>>> choose sound option>>> right click on sub option and then delete it... restart the nb it will reinstall it automatically if its window vista or window 7. and if its xp you need to reinstall it manually.
- update the driver from internet
Mar 25, 2010 | Compaq Armada E500 Notebook
Jag vill downloada ljudkort som heter soundmax
>> I want to download sound card which is called SoundMAX
>> Which side you can install for free?
If the manufacturer is Creative Labs, download from http://www.SoundBlaster.com
Nov 29, 2009 | Microsoft Windows XP Home Edition
Keyboard
It the same as pressing CTRL and ALT at the same time.
Jun 26, 2008 | Microsoft Computers & Internet
Some keys can not work at all
hi first: buy a cheap new 1, u can find in EBAY 20$ or even less BUT U ASKED its a iiky job and the chances are not with you for success but you asked 1. turn upside down the kebord through all the process 2. open all the screwes 3. slowly lift the upper lid clean all the dust and $@(&#* underneath 4. put everything in place 5. close the lid 6. open it and put the knobs u missed 7. close the lid with the screwes 8. see if you put all the knobs right 9. hope it will work at all 10. works? - good for you dont work? I TOLD YOU!!! GOOD LUCK
Dec 30, 2005 | Toshiba G83C0001K210 Keyboard
Computers & Internet Logo
David Payne
David Payne
