Question about Amana ARB2205C Bottom Freezer Refrigerator
Defrosted manually two weeks ago; appears to be frosted up again and freezer losing temp. Think some component of auto defrost not working; how do I isolate which?
  • 259 Answers
You most likely have a defective defrost thermostat in this model. It is located behind the cover in the freezer compartment and is a small round device with two wires attached to it. It is attached to the freezer coils on the top right hand side. It usually has an orange and a brown wire connected to it.
Part number is 12001937 and should cost about 23.00. This part should read "closed" on a continuity check when it is frozen, and opens when it is warmed above about 55 degrees.
The idea behind this part is to shut off the heaterDefrosted manually two weeks ago; appears to be - 2_bing.gif during defrost should it get too warm in the evaporator area, however when they fail it does not allow the heater to come on.
Posted on Jul 03, 2010
Siemens KG39NA00GB fridge freezer auto-defrost problem.
When you defrosted manually, did you get a lerge amount of water down the back of the unit? If not. the drain is blocked. Also clean and clear the condenser
Apr 24, 2012 | Refrigerators
Appears to go into an extended defrost cycle.
Sounds like your freezer has a bad defrost thermostat ( bimetal ) or bad #4 and/or #5 thermistor . This bimetal , has a high temp rating of 140 degrees , which means , when it gets to 140 behind the panel , it will cut off the defrost heater , to keep ice and food from thawing . The thermistors , tell the main control board the temps , and it decides when to restart the cooling process . I would check the thermistors by the digital controls , in the test mode , or have a technician check them for you .
Sep 12, 2009 | GE Refrigerators
Need photo of freezer defrost sensor, switch or thermostat
Before replacing all of the components mentioned above, locate your defrost heater and check for continuity with an ohm meter,this will ensure no breaks in heater coil
Jun 29, 2009 | Viking Professional VCBB363SS Stainless...
Frost built up all down the back wall of freezer and temp is down
I just had the same problem a few weeks ago...it was the defrost motor in the freezer...here is a quick fix..until you can get it fixed...turn it off...get it defrosted...all ice gone...and the defroster will work again...if you have one of those steam cleaners..that will defrost it fast!!!
Mar 30, 2009 | Refrigerators
Freezer all frosted
i have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Jan 06, 2009 | Maytag Refrigerators
Indesit BA139 fridge freezer with very thick frosting on back wall, but not very cold fridge section (despite changing the temp control to max) and normal very cold freezer section. When temp control...
One or more of your defrost components(defrost timer or board, defrost heater, defrost thermostat/ bi-metal) are bad. Unless you removed the inside back wall in freezer and completely thawed the evaporator, it will not cool properly.
Aug 25, 2017 | Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Amana ARB2205C Bottom Freezer Refrigerator Logo
93 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
