My Office jet 7110 says the yellow print head is bad. Can this be fixed? I just replaced the red printhead and the color ink cartridge. It will not print yellow when I did the test.
  • 2 more comments
  • lola1964 May 30, 2008
    My printer reads bad printhead on magenta and yellow, but they are new. Any suggestions?
  • rmvannord Aug 04, 2008
    We have an hp offricejet 7140xi all-in-one that said the magenta print head was bad. Replaced it, cleaned and alligned but still said the same thing. Pulled it and the yellow out, reinserted and now it says the yellow printhead it bad. It has a new ink cartridge. What is going on?
  • HP7130 Sep 26, 2008
    I received an error message stating that the yellow printhead is damaged on my HP Officejet 7130 printer. I replaced the yellow printhead and attempted to align the printheads. It failed and still states that the yellow printhead is damaged. Any recommendations?
  • Anonymous Dec 18, 2008
    brand new print cartridge. Printer is reading bad magenta cartridge.
Unfortunately the only fix is to replace the printhead
Posted on Apr 17, 2008
I have an HP Photosmart C3180 printer color ink issue. Instead of printing yellow its printing pink. I've cleaned the head multiple times and the ink cartridge is brand new. Please advise. Thanks!
If what you're saying is still the result after cleaning everything up, there must already be something wrong with the printhead because the printheads are the one's that are responsible for the mixture of the ink cartridges.
Try calling HP Tech Support. They might still be able to replace the printheads for you.
Feb 03, 2011 | Office Equipment & Supplies
My office jet L7590 printer suddenly quit on me. It keeps playing a message that says the printhead has a problem
Did you let one of your inks run dry? If so, you need to replace the effected printhead. This model has two, one for black and yellow, and a second for cyan and magenta. If you let the yellow run dry but have tons of black, it still effects the black/yellow printhead. Same with the other, either color going dry makes its printhead go bad. Either printhead will set you back about $75. Easy to remove and replace once you get the new printhead.
Bottom line with this model of printer...DON'T let you inks run dry. A new ink cartridge is $20 vs. $75 for a new printhead.
FYI - This is the most common mistake/problem with this printer. The Inkheads are built to last at least 40,000 prints. That's several years for most of us, that is unless you let the inks run dry.
Feb 09, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
My blue color does not print
Remove the Color and Black Cartridge >
Remove the Printhead by pushing the grey latch with your thumb going upwards
close the access door without nothing on it
unplug your power cord > re connect after 10 seconds
reinsert Printhead and Ink cartridges
goodluck....
Sep 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hp 7110 Printer erro
I'm not sure you specified the correct printer. The 7110 printhead is not pentagonal. Is your printer the 7110 all-in-one?
Jun 19, 2009 | HP OfficeJet 7110 All-In-One Thermal...
New tri-color ink cartridge prints only red
Are the Jets clean and unobstructed? Depending on printer model, have you cleaned your print heads? Consider also it may be a defective cartridge.
Sep 09, 2017 | HP OfficeJet t65 All-In-One InkJet Printer
Cannon i 960 printer
Try first replacing the cartridge , possibly with an original one.
With new printer cartridge on do head clean a couple of times, to clean the print head.
If it still prints wrong color then the print head is faulty, one of the colors jets is clogged.
You can remove the printhead and leave it in cleaning solution or isopropyl alcohol overnight, probably you will need to replace the printhead.
Sep 10, 2008 | Office Equipment & Supplies
HP Office Jet 7110 All-in-One
Here is a copy of the manual
See page 58 on how to calbrate and test the print heads. If that doesn't work replace the black print head.
Sep 03, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Red and Yellow not Printing at all.
Did you use third party carts?
If yes, buy original brother ink carts and do the cleaning cycle again. If you are lucky the printhead isnt clogged due to the third party ink which has not the additives and glycerin needed for the printhead to run without probs.
In case the head is clogged there is nothing more what you can do. Sorry!  A replacement might costs more than a new mfc 440cn!
Oct 16, 2007 | Brother MFC 420CN All-In-One InkJet...
Supply expired
So many models. Does this model have printheads under the ink carts? If so, remove the print head and clean the jets with a damp Bounty paper towel. Fold the towel up a few times and blot the head into it a few times to clean out the dries ink.
Aug 09, 2007 | HP OfficeJet 6210 All-In-One InkJet...
278 people viewed this question
jasbo
jasbo
