Most people, when the light comes on, your abs is down, either fix it or not, you still have brakes, but no abs, so most can't afford the $1500 to put into a 12 year old car. They tape over the light and drive away. My light came on 8 years ago, I took out the bulb. Never noticed the difference. The unit in front of the power assist unit is what needs changing,,, I think,, Not sure, It is called, ABS Hydrolic Unit , the ABS Pump Motor ,and the ABS Module could be at fault also. So, if it was the rear only, it would be great, when was the last time you had to stomp on your brakes? Get out the tape, I didn't tell you that, it is what I did. Hope this helps.
