Question about Kodak EasyShare C713 Digital Camera
Whe I turn the carmera on it says lens error and then the whole camera shuts off, I am not sure what to do . Is it broken?
    President:
  • 405 Answers
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Posted on Jul 02, 2010
When i try to turn my camera on it sounds like its going to turn on but it stops and gives me the message on the screen Lens error 111. then it shuts off. I've been messing with it and i can get it to...
Often times a lens error comes up when the lens extension/focus mechanism has been jammed. It may almost fully function, but then the gears run into a small spot where those tiny gears are jammed, broken, have debris on them, etc. When the motor hits unexpected resistance, the camera kicks back the lens error code and shuts down before it does further damage to itself. Make sure there isn't anything wedged between where the pieces of the lens slide past each other. Past that, the best solution I can offer is to look on ebay... most cameras either die because the lens mechanism breaks, or because the LCD screen breaks. If you can find a donor camera with a bad screen, you can combine the best of both at a pretty reasonable price. These cameras are quite complicated to transplant, but fortunately most lens mechanisms and sensors are a full unit of themselves, and so are the lcd screens. Before investing in the donor camera, take yours apart and see how difficult it appears to be to work on it. Then make your decision. Good luck!
Aug 13, 2011 | Cameras
I have a canon camera IXUS 105 and the lense is stuck out and when i turn the camera on it says 'lens error, will shut down automaticly, restart camera' i have restarted it many times but the lenses wont...
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Mar 05, 2011 | Canon Cameras
"Lens error, restart camera"
change the lens cover and change the battery please vote
Nov 04, 2009 | Canon PowerShot A1100 IS Digital Camera
Lens error
if the problem is due to the fact that u have dropped the camera on floor or put into water...then no other go you should change the whole lens array...contact your nearest service centre
May 13, 2009 | Nikon Coolpix S210 Digital Camera
Lens error in S3IS
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 22, 2009 | Canon PowerShot S3 IS Digital Camera
Every time i try to turn on my carmera the screen says lens error what does it mean and what should i do about it?
it means your lens is broke mine does it every time i try and turn it on and i have to get a butterknife to open myt camera up to use it its a big hassle what you probly did was had it in a bag or something and the bag was dropped and the cammera lence face got jammed.
Sep 02, 2008 | Cameras
It says lens error
its probably broken but the black slides that cover the lens if you play with it alot or push them in when the camera's turned off the lens mess up or if you've dropped the camera too much the lens break on the inside.
Jan 22, 2008 | Optimus DC-5347 Digital Camera
Minolta maxxum 7000 35 mm camera
I had the same problem. After I replaced the lithium backup battery, everything works perfectly. It is a CR2016 watch battery and it is located behind the silover plate inside the battery compartment. Remove the 6 screws and replace the battery. Note the polarity when you remove the plate because the camera will not operate if if it is put in backwards.
H
Nov 14, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Kodak EasyShare C713 Digital Camera Logo
247 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
