Question about Linksys BEFSX41 Router (DHBEFSX41)
Befsx41 router doesn't work with wrt120n router
    Guru:
  • 528 Answers
Hi. Could you give me more information of the problem. Is there any error message or what happens when you connect both gadgets?
Posted on Jul 02, 2010
  • 3 more comments
  • info86599 Jul 02, 2010
    The setup is as follows:
    internet
    befsx41 (ip 192.168.1.1) (VPN setup)
    wrt120n (1p 192.168.10.1) DHCP enabled - wireless laptops and windows 2003 server connected
    Note:
    The befsx41 should be connected to another befsx41 for VPN connection (other location).
    Regarding the setup wrt120n and befsx41 there is no internet connecion usinf adsl modem.
  • Archie Cruz
    Archie Cruz Jul 02, 2010
    Is this the first time you setup the devices? or is it working before?
    befsx41 (ip 192.168.1.1) - > is this the gateway IP of the router?
    wrt120n (1p 192.168.10.1) - > gateway ip of the wireless router with DSL connection?
    please verify.
    Jul 02, 2010
    - Is this the first time you setup the devices? or is it working before?
    answer:
    - This is the first time
    - Befsx41 --- the gateway ip of he router with dsl connection (attached to the modem for internet connection)
    - wrt120n --- gateway of the wireless router without dsl connection
  • Archie Cruz
    Archie Cruz Jul 03, 2010
    ok. so the connection is from befsx41 (with dsl modem) going to wrt120n then going to computers. is this the setup?
  • info86599 Jul 03, 2010
    yes
3 Suggested Answers
  • 345 Answers
SOURCE: WRT120N doesn;t permit VPN accesses
Most times when VPN is not working is because one of the ports is not forwarding right. Easy fix is to go to router settings and enable DMZ for your computers IP address. Also you can actually find out what are the ports this VPN uses and go to Port Forwarding part of router and open the ports manually. My favorite is DMZ. All this does is open up ports for your computer IP address so there is no blocked pockets. Good luck.
Posted on Jan 12, 2010
SOURCE: How to install a wrt120n
hi
go to folowing link you will have your solution for Linksys router and setups
http://www.homeserverland.com/wiki/w/whs/linksys-wrt120n-router.aspx
Posted on Jun 27, 2010
Can i hook up wrt120n to laptop without hooking up to cable modem to fix?
Try this: Unplug EVERYTHING(related to both the router and modem). BEFORE you plug in power to anything, connect all of your ethernet. So, first ethernet goes from modem to router. Make sure they are in their proper places. Next, take another ethernet cable and attach that from modem to computer. NOW, power everything up. Google the linksys router splash page login. Im sure it'll be something like: 192.168.1.1 or 192.168.0.1 or something along those lines. From there, you should be able to set up your wireless. Once thats all good, unplug just your computer and everything should be fine. If that doesn't work, its either time for a new router or you're having wifi card issues.
Apr 28, 2012 | Linksys WRT120N Router
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
I want to change my id user name & password for WRT120N. But I also can't find the program in my computer. Please assit me. Thanks,
In order to access your WRT120N control panel UNDER FACTORY SETTINGS, you must navigate to http://192.168.1.1 in your web browser.
According to Cisco's support site, the default username for the WRT120N will be NULL (left blank) and the password will be "admin".
Once you reach the control panel, navigate to the 'Administration' section, where you should be able to change your username and password.
NOTE: If this does not work, you may want to look into performing a factory reset of your device.
Jun 07, 2011 | Linksys WRT120N Router
Lost setup disc(CD)......have a WRT120N Cisco/Linksys....and really cannot install it to connect wireless for gaming on Playstation 3 and for internet/email on Laptop.....Wondering if I could get a...
can you "see" your wireless in "available wireless networks" as you did before? if so you may just need to restart your pc if you haven't since you moved it. if that doesn't help you can check the router settings...
open internet explorer and at the top type "192.168.1.1" that should bring you to the log in page. clarkcanhelp_3.jpg
if you never changed it, try user-admin and password-blank. if that doesn't work try admin-admin, admin-password.
when you get in click on the wireless tab and make sure its on/enabled.
then go to security tab and make sure you lock out others from accessing your internet. clarkcanhelp_0.png
hope this helps
Apr 18, 2011 | Linksys WRT120N Router
I have problem connecting new computer to befsx41
1.Unplug the router for 1 minute then plug it back into the AC . Wait........ 30 second to see if you have acquired a signal
2. Confirmed that you have connectivity with the ISP ( internet service provider)
a.Check your wireless setup and see if the wireless is on.
b. do ipconfig / all
c. test the router by setting up the router by MAC address..
Jun 19, 2010 | Linksys BEFSX41 Router (DHBEFSX41)
Jan 12, 2010 | Linksys WRT120N Router
I am unable to connect Linksys BEFSX41 and Sonicwall 3060
Check out this post:
http://www.dslreports.com/forum/remark,5336853
This person seemed to have no problems with it and includes configurations.
I would also make sure both are the same version or same firmware, I have had trouble in the past with netgears having different firmware not allowing a vpn to be configured.
Jun 26, 2009 | Linksys BEFSX41 Router (DHBEFSX41)
Linksys befsx41 firmware
Hi dear go to this link http://www.linksysbycisco.com/US/en/support
From here you can download
Thank you
Imran
Pls rank as possible have nice day
Apr 20, 2009 | Linksys BEFSX41 Router (DHBEFSX41)
Linksys BEFSX41 Router (DHBEFSX41) Logo
37 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
