Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE Profile icemaker auger gets stuck
I have a GE Profile side by side refrigerator. I am having a problem with the auger in the icemaker. The motor works fine, but the auger gets stuck. I can't even turn it by hand. It appears that it is getting stuck on a piece of ice where it is supposed to be dispensed from. I'm confused, though, because isn't that what is supposed to crush the ice? If I clear out the ice the auger will turn but another piece of ice immediately gets stuck there. It does this whether I choose crushed or cubed ice.
SOURCE: Ice dispenser not working - GE side by side refrigerator
Check auger motor if getting power then probably motor gone , if
not may be switch. good luck
Posted on Nov 09, 2007
MNTECH
  • 1543 Answers
SOURCE: PSS26PSTA SS - Only dispenses crushed ice.
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
Posted on Nov 20, 2008
MNTECH
  • 1543 Answers
SOURCE: Ice maker only makes crushed ice
Pull the ice bucket out. Behind it you will see a rectangular hole with a rod in it. The rod should be able to move with your one finger up and down. If it does not, the solonoid attached to it is either frozen or burnt out.
Posted on Nov 25, 2008
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
SOURCE: Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
I have a GE Profile Performance side by side refrigerator and I can no longer get ice through the door. I can get water but the ice and crushed ice just humms . It does not dispense. Any ideas?
The humming you hear is probably coming from the motor not being able to turn the auger. Check to see that the auger is intact. I have seen where they come apart and get jammed up. Here is the part to order in case you find it bad.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | GE Profile Performance 25.2 cu. ft....
GE P5Hs6RGXBDSS sidexside with ice/water disp. Makes ice well but ice not propelled down shute. No blockage
Check to se that the auger is turning when you push the button for ice. If not, replace the auger assembly or the auger motor!!
Jan 31, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE PSS26GRE SS not dispensing ice
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Icemaker will not dispense tho ice is in drawer,
There 2 possibilities the auger motor is bad or loose wiring connection or the control switch is bad in the dispenser control. I can assist you if you like. Will wait to hear from you, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
or http://appliancepartsandtechnicalservices.blogspot.com/
Jul 02, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker drive mechanism won't turn
Remove ice bucket and rinse throughly. Hold down door switch an press for ice you should see the drive in the back for the auger turninig if not youll need to find out uif auger motor is getting electricity and/or is operable.
Mar 15, 2009 | GE Profile PSS26NGS Side by Side...
Ice maker will not dispense ice.
ON THE AUGER MOTOR IS A COUPLER THAT SLIDES INTO THE AUGER WHEN THE BIN IS INSTALLED. SOMETIMES, THE COUPLER WILL ROUND OUT THE FLAT SIDE OF THE CENTER HOLE. THIS WILL CAUSE THE MOTOR TO CONTINUE TO TURN, BUT THE COUPLER WILL REMAIN STILL DUE TO THE RESISTANCE OF THE BIN AUGER. ALSO, BE SURE THE ICE IN THE BIN HASN'T MELTED TOGETHER BINDING UP THE AUGER. IF NECESSARY, REMOVE THE ICE AND START OVER WITH FRESH ICE. YOU MAY NEED TO REPLCAE THE COUPLER OR AUGER MOTOR.
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is going to dispenser in door but not to icemaker.
The first thing I would look at is the two solenoids on back of refrigerator. Each of the two have 2 wires. Switch the two sets of the two and then try the water dispenser. If the dispenser then don't work the ice maker should begin filling. If this happens you will need to purchase a new duel solenoid for that fridge. Hope this helps, Sea Breeze
Oct 28, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
216 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
