Question about Polaris 3900 Sport Pool Cleaner ()
I purchased a Polaris 3900 on 6/2/2010 and have already replaced two filter bags. Both times the bag has become wedged between the chasis and the wheels tearing the bags. Any suggestions?
  • 640 Answers
First, make sure that the velcro closure on your pool cleaners bag is sealed tightly. If the velcro is coming lose, it could be the problem. Next, make sure that your wheels are operating at the proper RPM. Too little RPM could cause the pool cleaner to be sluggish and not create the proper tension to keep the bag floating. It should be between 30 and 36. If it is running at less than 30 RPM, there are few things that you can do to fix it. If an adjustable valve is installed on the cleaner line, open it completely so water can flow freely to the cleaner. Check the filter screen in the in-line filter
for debris that restricts water flow and clean if necessary. Also clean the skimmer, filter, and pump baskets. Check the hoses, connections and swivels for leaks that cause loss of water pressure. Finally, if none of these solutions work, remove the blue restrictor disk from the UFW.
Posted on Mar 30, 2011
Not sucking on the floor side
Hey Anthony,
Sorry to hear you're having some problems with your vacuum. There are a few different things you can try to remedy the situation.
First, check all of the filters in your vacuum. Over-time your filters (air/exhaust) may become clogged and need to be cleaned or replaced for proper function.
Second, check to make sure there are no obstructions in the vacuum hose. If something were to become lodged in the hose it could affect the unit's suction.
Third, check to see if the vacuum bag is full. If it is full your vacuum won't be able to pick anything else up.
We offer a wide variety of replacement bags and filters that you may find of use. You can purchase replacement products direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 14, 2015 | Dyson DC31 Animal Bagless Handheld...
Polaris 280 pool cleaner won't suck uP debris into bag
if pressure ok at wall and filter is clean check inside unit to see if hoses came off put on and zip tie
Mar 19, 2013 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 3900 wheels won't turn
check inside see if belts or hoses came off
Oct 20, 2012 | Polaris 3900 Sport Pool Cleaner ()
Since I replaced the bag in my Eureka Rally 2 (this was the first time) the suction has not been working well. Could you please tell me what I could have done incorrectly. Thankyou
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Mar 28, 2011 | Eureka Vacuums
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
Dec 25, 2010 | Eureka Vacuums
Fine particles going thru the bag
Check the bag of your pool cleaner to make sure that it doesn't have any holes or tears that should not be there. Some fine particles will not be picked up by pool cleaners, no matter how effective. If your filter is not catching the debris, you might need to manually brush the bottom and sides in order stir the dirt up into the filter.
Aug 05, 2010 | Polaris 3900 Sport Pool Cleaner ()
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
Polaris 380 stand on nose while on will not move off
There are several things that you can check on these automatic pool cleaners to try and correct this problem. First, make sure that the filter bag is not full. A weighed down bad can cause the cleaner to tip onto the nose. If there is water in the head float, you will need to replace it. Make sure your hose floats are spaced correctly so that they are not causing the cleaner to float incorrectly.
May 17, 2010 | Polaris 380 In Ground Pool Cleaner
The service air bag light is on.
Sometimes the wiring under the passenger seat can become compromised from objects in floor becoming wedged under the seat.May need to be reconnected if possible..Usually if the air bag light remains on , it means the air bag will not engage if needed. Should have the dealer service department check for you.
Aug 21, 2009 | Hyundai Motor 2005 XG350
Polaris 3900 Sport Pool Cleaner () Logo
194 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
