Question about Compaq Deskpro EP PIII-650MHz/ 128MB/ 10GB/CDROM/ FDD/ ENET/ Keyboard/ Mouse/ WIN98COA/ No OS - (CODEEPPI1210) PC Desktop
I bought this computer on 22/3/08 and this is the second time I have had this problem. My CD/DVD Drive has suddenly stopped working.In the devive manager the code error is 10. The model of the computer is GM5066B and the serial no. GSG7211000075. Thank you Eleanor Gibbs
    President:
  • 2,712 Answers
Basically it means that if the device which is causing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)" Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for your CD/DVD Drive. You can also try uninstalling and reinstalling the device, using the disk which came with it. When doing this, make sure to restart your computer. This may help clear up the problem.
Finally, you can go to the website of the device's manufacturer, and check their download or support section for current, up-to-date drivers and patch kits.
You should also check out this site:
http://errorsmart.com
Hope this helps..
Posted on Apr 17, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 01, 2008
    Just checking to see if your issue has been resolved… If
    you find that the solution/answer I provided led you to, or resulted in a fix,
    please close the ticket with a FixYa! rating under my solution.
    I
    would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 28, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
    Scholar:
  • 55 Answers
This COULD solve your issue, although it IS risky...
A) Start Registry Editor (Start, Run and type in regedit then click O.K)
B) Locate the UpperFilters value under the following key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
{4D36E965-E325-11CE-BFC1-08002BE10318}
C) On the Edit menu, click Delete, and then click OK.
D) Locate the LowerFilters value under the same key in the registry:
E) On the Edit menu, click Delete, and then click OK.
F) Quit Registry Editor.
G) Restart your computer.
Kind Regards,
Stef
  • Stefan Groevens Apr 18, 2008
    @ Irish Druid =
    I don't think the driver is not installed when he said that it was working previously and suddenly : OUT OF THE BLUE : he gets an error code 10 ???
    @richard1st =
    Does device manager tell you : Unknown device or PCI device or does it have a proper driver name ???
HP Slimline s3500f, Vista 64-bit. CD/DVD stopped working. I've reloaded the driver several times. Device manager says it is working properly. I have removed upper and lower filters in registry, I have...
A couple of suggestions.
1) Download HP Support Assistant to check for updates on your machine
2) I assume you are using Windows Media Player. Try another free program like VLC. Its handy to have 2 installed so you can toggle between the 2 if one is having problems.
Sep 18, 2017 | HP Pavilion Slimline s3500f Desktop...
My Compaq Presario 1700T will not play DVD anymore. It worked before. Now when I insert a DVD I can hear DVD spin for about 2 seconds then it stops spinning momentarily, then it spins for another 2...
IT'S 16 years old, there is no support for it now. sorry.
we get these here all the time, and no OS stated
why post with out stating what OS this is,
?w98, w2k, XP, VISTA,W7,W8, w8.1 W10.?
nor showing the DVD model there, it has s specific model name
and number (vast types used and sold)
DVD from store, or one you made or others made by hand.
home made or factory made store bought DVD?'
did you try this?
did you try other DVD movies? or look for the VOB files on them?>
Testing 123, easy to harder,
1: try a music CD first. store bought not home made.
2: look for files on any install CD, using the local file manager.
my computer, this computer, or what ever ms calls it this year.
we look to see if the PC can see the files on a real CD. first.
even the HP install CD, or other CD that are not for music or movies, if it cant read a CD, and see fails drive is bad.
or its drivers are missing or corrupted,(virus or?)
3: if this fails open the control panel, (start , CP) then look in device manager (on XP it tricky to get there so tell us if it's XP)
no OS stated, so....no operating system stated.
if the Device manager fails to show the DVD DRIVE,
this means :
A: bad. drive.
B: drivers for the drive are missing (hp has them if still HP DVD drive)
C: the OS is corrupted.
D: running XP , the Dead OS, with out SP3 service pack 3 will be very bad experience in all ways. it has DVD driver in said pack.
E: not running the HP drivers, that hp has. (but HP does not support 16 year old PCs at all) so getting them now is super hard.
the users manual mentions windows 98.
omg is it that old?
the same manual says , only select models has DVD drive.
to make DVD work , special software from HP was installed.
From HP, not MS.
there is a free manual for your PC
https://www.manualslib.com/manual/428472/Hp-Compaq-Presario-Presario-1700.html
Oct 17, 2017 | HP Compaq Presario 1700T Notebook
Samsung DVD writer suddenly not working.
Hi there..
I can understand the issue.
There are 2 ways to fix this up..
FIRST STEP :
Check whether the drive is listed in My Computer or not.
If its not detected then reboot the computer and get into BIOS.
Check whether CD driver is detected in BIOS.
If its not then i'd say please try to swap the cable between HDD & CD drive and restart the computer.
Check whether the computer is booting or not.
If not we can come to the conclusion that the drive is gone bad.
SECOND STEP:
If the drive is listed in My Computer and still not working.
Then i'd say please go to SERVICES.MSC
Locate for the option IMAPI CD-BURNING service and right click on the option.
Go to properties and start the process and make the startup as Automatic. I've given the screenshot here.. Kindly go through it..
Click on start and now you reboot the computer and now check in My Computer whether you see CD Drive.
OR
The next step which we are going to follow up is very important.
Start->Run->regedit
Locate for the upper filter & Lower filter. Here is the location for finding the upper and lower filter..
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
After you click on the 4D36E965-E325-11CE-BFC1-08002BE10318 option take a look on the right side you can find upper & lower filter.
Delete it & Restart the computer and now you are offset..
CAUTION: Use Registry Editor at your own risk. Any change using Registry Editor may cause severe and irreparable damage and may require you to reinstall your operating system. Internet Security Systems cannot guarantee that problems caused by the use of Registry Editor can be solved.
Jan 14, 2010 | Samsung Super-WriteMaster SH-S183L Burner
Dell Inspiron 8600 Cd RW/DVD has stopped working
this problem occurs when the lens of the drive gets weak or broken
you can either buy a new drive or just get the lens of the old drive replaced
yes its possible to replace a cd rw/ dvd drive with a dvd rw drive
Sep 29, 2009 | Dell Inspiron 8600 Notebook
My dvd player on my laptop used 2 work but now it suddenly stopped working and i cant get it to work it doesn't seem to recognise that there is a dvd in my computer. i have tried playing it in every single...
You may use any CD/DVD drive lens cleaner to clean the lens as it may be that the lens in the CD/DVD drive is not able to recognize the disc due to accumulation of dust. Next, you may perform System Restore to the time when the CD/DVD drive operated normally. If the issue persists then you may try reinstalling the Operating System.
If the issue persists even after performing all the above mentioned steps then the issue may be Hardware related and the CD/DVD drive may require service.
Jun 06, 2009 | Computers & Internet
My CD/DVD Drive has sudenly stopped working.In the devive manager the code error is 10. The model of the computer is GM5066B and the serial no. GSG7211000075. Same problem on a Compaq Presario SR5213 with...
Things to check
1. See if the drive is identified properly in BIOS, if it is not, reseat all cables and try agian.
2. Can you boot to the drive using a bootable CD (XP CD or such) If the drive functions outside Windows, then it is a software issue. If it doesn't boot to bootable media, then you most likely have a hardware issue.
If you can boot to the CD, then try booting to the safe mode, removing the drive from device manager then remove the upper/lower filters in the registry then reboot in to the normal mode.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Jan 25, 2009 | Compaq Presario 5000 PC Desktop
My dual layer DVD burner wont read any media
When was the last time you cleaned the dust out of the laser head? Or your PC, for that matter? Just asking.
There are cleaner disks that work sometimes, or you can go in with a cleaner foam swab with a little alcohol on it. Worth a try.
Apr 08, 2017 | LaCie (300978) DVD RW Dual Layer Burner
CD/DVD DRIVE DOES NOT READ PROPERLY
Really the ONLY thing one can do.. is replace the unit with another know good working one.. IE:New. Usually a GOOD CD/DVD will instantly & always work... it will be picked up by windows and then the appropriate "Drivers" installed. As an IDE CD/DVD is "Generic" it generally doesn't require a "Special" Driver, so windows uses it's "Own" driver. Therefore generally if it's showing as OK in Windows, but is NOT going... then, usually, as I said, it is kaput.. for some reason... usually the laser Diode or Quadrant detector...
Aug 30, 2007 | Computers & Internet
Compaq Deskpro EP PIII-650MHz/ 128MB/ 10GB/CDROM/ FDD/ ENET/ Keyboard/ Mouse/ WIN98COA/ No OS - (CODEEPPI1210) PC Desktop Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
