Heating & Cooling Logo
Posted on Jul 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After installing an air handler for a heat pump system, the condensation started. the air handler sets in an outside, unconditioned space. it is well insulated,and all connections sealed with mastic. it is a two zone system with a bypass in the mech room. what is a fix for this system?
Anonymous
Level 3:
  • Master 1,515 Answers
  • Posted on Jul 02, 2010
Anonymous
Master
Level 3:
Answers
1515
Questions
Helped
628719
Points
4388
Hi, on the refrigerant lines that are now condensateing, all you can do with them that are exposed are to wrap them with the black insulation made for this and make sure you have your condensate line connected to the air handler at the evaporator coil with either pvc or hard copper. I have never had to put mastic on any joint in case I had to take it apart for some reason. It sounds as though you have all of the lines insulated and that. I am not sure what type of insulation you used on the pipe, but it takes the armour flex. It comes in 10' sections. That's about the only fix there is. It has to have a condensate line from the indoor coil to outside to let most of the water run off. You are not going to be able to get rid of all of the moisture, but if the heat-pump is set up correct as for the super heat and sub-cooling, it shouldn't condensate that much.If it gets bad, try the armour flex and the black pipe wrap. This should help you a lot. Keep me posted .
Sincerely,
Shastalaker7
A/C & Heating Contractor
What ton unit is this air handler RCHL-36A1GH21
An Air Handler is just a blower. It it can handle more air than the condenser it will never be overworked or freeze up.
RHEEM Used Central Air Conditioner Air Handler RCHL- ...
Used AC Depot https://www.usedacdepot.com > rheem-used-central-ai...
Stock Number: ACC-13265. Equipment Type: Air Handler. Cooling Size: 3 Ton. Refrigerant Type: R-22. Manufactured Year: 2012. Heating Type: Electric.
US$413.00
INSTALLATION INSTRUCTIONS
MyRheem Portal http://pts.myrheem.com > 92-20521-44-06_BHP
?WARNING ! These instructions are intended as an aid to qualified licensed service personnel for proper installation, adjustment and.
32 pages
Used AC Warehouse https://www.usedacwarehouse.com > product > ACC-1...
DESCRIPTION ; Model - Air Handler: RCHL-36A1GH21 ; Air Handler Configuration: Vertical ; Application Type: Residential ; Electrical: 208/230 Volt-1 Phase.
US$413.00
Ruud High Efficiency Air Handler
Coburn's https://library.coburns.com > specs
Internal checked TX valves are used on the RCHJ & RCHL. Heat Pump indoor coil ... RCHL-36A1GH21. RCHJ-36A1GH21. 21. RCHJ-48A1GH24. 24. RCHJ-60A1GH24. 25. 4. R- ...
16 pages
1helpful
Why does my American Standard heat pump compressor and condenser fan run when I have the thermostat set to emergency heat?
It's possible the "brain" thinks it can still supply some heat. Other wise there is a wiring problem or thermostat switch problem. Installed recently? Never used emergency heat before? What is your emergency heat type, gas or electric? Are you sure they are working. If not the "brain" senses and uses the only source available: heat pump. Thermostat? probably Honeywell? If so call Mfg customer service. Warranty on thermostat or heat pump? If so call customer service. Call your installer.
1helpful
Hey, I purchased your Honeywell RTH2510 Thermostat, but I didn't even think to label the wires when I took the old thermostat off. Upon installation of the new Thermostat (2510) the Air Conditioning...
The connections that you really need to reference would be at the air handler itself. That would tell you which wires go outside to the heat pump and which wires go to the air handler. I can however give you some basics that may help.
Heat Pump Wiring
Terminals/Colors/Function
R- Red- 24v power supply. (Usually a jumper between RC/RH)
G- Green- Fan
W- White- Heat (Sometimes W1-W2, first or second stage heat)
Y- Yellow- Cooling (Same applies as above i.e. Y1-Y2)
C- Common (Most people use blue unless it is used for B terminal and sometimes cooling on older 4 wire systems.
B/O- Reversing Valve for heat pump. Either powered heating or powered cooling, depending on system installed.
Aux- Also used for heat.
Note: Considering that the installer had their own way to run all wires, use different wires, connections, etc. This is just a reference to common wiring in the field.
How the most common system is hooked up:
Thermostat:
Red wire goes to R terminal
Yellow wire goes to Y1 or Y2 terminal
Green wire goes to G terminal
White wire usually goes to W1 or W2 terminal
Orange or Black wire goes to B/O terminal
Brown wire usually goes to Aux terminal
Blue wire goes to C terminal, unless its being used as stated above.
This is without using a fossil fuel kit or zone control board.
Where do they go from the thermostat?
Red
goes to the air handler transformer or board and goes outside to heat pump to power low voltage controls.
Yellow wire goes straight outside to Y terminals on heat pump unless going to a board inside first.
Green goes to the air handler fan relay.
Common goes to the air handler and outside to heat pump.
Black or Orange will go outside to heat pump terminals for reversing valve.
White usually goes outside to heat pump,and inside to air handler. Will explain reason further down.
Brown will go to the air handler to the heat relay for the emergency heat.
On a call for heat, with a powered cooling system (more common).
The R, Y, and G terminals energize, sending a signal to start the blower and pull in the contactor outside. Note that the Y terminal is usually cooling, but since this is a powered cooling system, the reversing valve is not energized, causing the system to run in heat mode. If you have powered heating, the reversing valve terminal will energize also. Depending on thermostat, if you set the temp substantially higher than room temp, it may kick on the emergency/aux heat to quickly raise the room temp. On a call for emergency/aux heat, the R, G, and E/Aux terminals are energized, turning on the electric/gas heat instead of the heat pump. This comes in handy since the heat pump can only pull so much heat from outside before its not enough to properly warm the house, usually around 30 degrees outside temp. If you are running the heat pump and the system goes into "defrost", the outside unit will send a signal back to the air handler, through the white wire I mentioned earlier, to tell the emergency/aux heat to come on while it is in defrost mode, providing heat whenever needed.
Again, this is just a reference guide to some basic wiring, but hopefully it will tell you where the problem is or at the least, give you a good start. There are variables in which things can change the wiring like a zoning system or fossil fuel kit. Even then, you should be able to get pretty close. Hope this helps and Happy Holidays!
Carrier split heat pump leaking condensate at right side of air handler and left side of outside condenser. Have had recharged once since new, unit is 1 plus years old
it sounds like coil may need leveled or drain cleaned out and if needed more refrigerant system has a leak and needs to be found and repaired. Is everything new (tubing,evaporator,and heat pump)?if so leak should be at a welded joint may be under insulation
I want to enable the heating component of my central A/C if possible, or install a heat pump in the unit.
You need a strip heater for the air handler portion if you want heat. That will almost certainly require a circuit upgrade too. It would not be practical to 'add' the heat pump. You would need to replace the entire condenser (outside unit) to do that. You would also need a different thermostat and probably a new thermostat wire to the outside.
Is a split a/c alc and a heating or heat pump?
a split system can be gas or can be a heatpump. a split system is when the condenser coil compressor and outdoor fan is outside. the other half is in the house close to your air filter .that well be your air handler. eletric heater. or gas burner .and indoor fan motor would be. i hope that helps you.
1helpful
Ok..here's one. I have entire air duct system that is condensating ON THE OUTSIDE, UNDERNEATH. I noticed the problem before and after cleaning the coil in a closet air handler. Air runs fine, cools normal....
not moving enough air or duct work is in a unconditioned space and needs to be insulate. what are your freon pressures, suction and liquid line temps, and indoor wetbulb
RUUD heat pump system does not cool properly.
With a heat pump system there are always going to be a back up heat strip inside the Air Handler.
If you detect a faint humming in the Condenser call your local service company and ask them to come and replace your capacitor in the condenser. The humming is from the contactor engaging but not being able to start the compressor due to not having the required Microfarads to start it.
Let me know if this helps
Top Heating & Cooling Experts
Paul Carew
john h
