Question about Acme 6001 Juice Extractor
The circuit breaker engages a few minutes after using machine and continues to shut off machine after restarting.
  • 24 Answers
Change the first c.b switch other than change for the motor
Posted on Jul 29, 2008
  • John Halpsburn Jun 05, 2012
    Specifically how would you do that and where would you get a replacement circuit breaker?
Yesterday by juicer kicked of the kitchen breaker? Twice.
You may just be overloading the circuit. Easiest correction - unplug something else that's running (or turn off a light) on the same circuit and see if the breaker still shuts off.
But wait - also important - was there any burning smell? If so, this is dangerous. It's a short circuit that occurs when a "hot" wire (black) touches another hot wire or touches a "neutral" wire (white) in one of your outlets. You should not use that outlet and have an electrician look at it. Or it could be a ground fault (similar to the short circuit - when a hot wire touches the ground wire on the side of a metal outlet box which is connected to the ground wire. For either of these, you need an electrician.
Apr 05, 2017 | Juicers
Sharper Image Juicer locking bar won't engage.
micro switch lever might be broken might want to post on youtube.com check video's
Mar 11, 2014 | Juicers
Cuisinart juice sqeezer throws circuit breaker
Is this a new juicer, have you used this before without the circuit failure?
Most circuits in the house will be are 15 amp breakers. If the appliance has a high amp load then this can cause it to switch the breaker turning on or off.(due to to voltage spikes) I have a waffle iron that does the same thing if my refrigerator cycles while the iron is on.
There are a few things that could cause this. But before anything else I would try the juicer in a different plug that is on a different circuit, like the living room for example. If that works well then I would start looking at you may need to replace the circuit breaker, they do go bad.
Apr 05, 2012 | Cuisinart Juicers
After juicing a few carrots[some of which were cut on a slant], or several spinach clusters, the machine seems to get off balance and begins shaking violently and making a racket at which point I have to...
There's nothing wrong. These juicers do not eject the pulp and go out of balance very
easily. If you continue to have problems you may have to go for a different type of juicer.
The Hurom or Omega VRT, expensive, look good if you're really into juicing.
Mar 05, 2011 | Omega 1000 Juice Extractor
Loud "pop" noise as if
The reset button is actually a circuit breaker in miniature but there may be a thermal fuse to protect against fire in case of failure of the circuit breaker.
If you are game, open the housing again and look for a device you don't recognize that is in series (in line) with a wire; it may be in an insulating sleeve and not immediately visible, appearing only as a thickening of the wire. This could be a thermal fuse.
They are not supposed to open under load but only when the temperature exceeds a limit and these do not reset. Unfortunately, these are now all coming from China and are not very reliable so may open even when the design temperature is not exceeded.
If concealed, you would need a simple multimeter to determine if it had 'opened' by checking for the continuity of the wire stretch.
Blenders in general are 'universal' motors which can use AC or DC and this type employs carbon brushes which do abrade with time and when they have become too short, they can become intermittent and cause such a popping sound too. Brushes are replaceable so you might check Waring's website to see if they offer a fixed-price replacement or brushes as replacement parts.
I would be prone to see the Waring restored since most replacement blenders are from China and have often more than just one problem even when new. One given to us as a present smoked while crushing ice so we retrieved our old Oster from its stash and tossed the oriental wonder.
Jan 09, 2011 | Waring Juicers
Juicier will not work at all
Try the juicer on another circuit to see if the breaker failed altogether on the circuit you were using. It's possible that the machine is drawing more power than it should and may need to be checked by an appliance service dealer. An electrician can also check the power draw at the breaker to see if it is being overloaded. If the machine itself is defective, it should receive professional service. Good luck!
May 07, 2010 | Champion G5NG853S Household Juice...
Don't know how to set up Jack lalanne power juicer
First, check that the switch is in the on position. Then, check that all parts are assembled properly. The unit has a built-in safety device that will not let the motor turn on if not assembled properly. The Power Juicer also has a built-in Thermal Cut Off Safety Switch. If the machine was running, then shut down due to accidental overheating, then there is a 10 minute cooling time before the machine will restart. This helps to protect the motor from seizing. Click on the link below and select your juicer model to view the instructions and operating manual
http://www.powerjuicer.com/customer-manuals.html
Apr 15, 2010 | Juicers
My juicer was in a flood. I sterilized the top part of machine, what do I need to do to the motor's section? thank you
put the motor section few weeks at drying, not very very hot, be careful, even so tthat can make a short circuit!!!!!!
Feb 15, 2010 | Acme 6001 Juice Extractor
My juicer keeps shutting off after less than 30 seconds
sadly FIXYA has no idea if you can return it or not as defective unit . check with place purchased
Nov 12, 2017 | Jack Lalanne Power Juicer (Stainless...
Will not start
Junk it and buy an Omega, they at least have a decent circuit breaker. Mine quit after starting it and the breaker won't reset. Fixed it with a car fuse.
Jul 14, 2008 | Juicers
Acme 6001 Juice Extractor Logo
82 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you an Acme Juicer Expert? Answer questions, earn points and help others
