Question about Compaq Deskpro EP PIII-650MHz/ 128MB/ 10GB/CDROM/ FDD/ ENET/ Keyboard/ Mouse/ WIN98COA/ No OS - (CODEEPPI1210) PC Desktop
My CD/DVD Drive has sudenly stopped working.In the devive manager the code error is 10. The model of the computer is GM5066B and the serial no. GSG7211000075.
    Scholar:
  • 55 Answers
This COULD solve your issue, although it IS risky...
A) Start Registry Editor (Start, Run and type in regedit then click O.K)
B) Locate the UpperFilters value under the following key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
{4D36E965-E325-11CE-BFC1-08002BE10318}
C) On the Edit menu, click Delete, and then click OK.
D) Locate the LowerFilters value under the same key in the registry:
E) On the Edit menu, click Delete, and then click OK.
F) Quit Registry Editor.
G) Restart your computer.
Kind Regards,
Stef
Posted on Apr 17, 2008
Can't get my cd/dvd rw drivers to work? Can't read the CD/DVD RW Tray?
Description of Code 10-related errors that Device Manager generates in Windows-based computers
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - then RIGHT CLICK the drive - UNINSTALL - REBOOT
this will refresh the default driver stack.
if this not work, replace the device with a new one.
Mar 03, 2015 | Acer 15.6 Inch LCD Screen Panel for Aspire...
I have a gateway laptop model m-6866 and all of a suden my cd/dvd drive is not working. Suggestions please.It closes and opens but when I insert the cd/dvd othing happens.In my device manager the cd...
Your CD/DVD drive may be fine, but some software is faulty. The repair is a very similar process for all Windows versions, which involves editing the registry, so use caution. Here's a my search results:
repair registry for dvd drive Google Search
as well as a link with repair instructions:
https://itstillworks.com/12171166/how-to-use-the-windows-registry-to-fix-a-dvd-drive
Dec 06, 2017 | Gateway M-6866 Notebook
Code 10 no cd/dvd drive found, unable to burn cd?
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Jun 24, 2009 | Apple iTunes
LG HL-DT-ST DVDRAM GSA-T10N error code 10
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Apr 03, 2009 | LG (DAD-8020B) DVD-RAM Burner
My CD/DVD Drive has sudenly stopped working.In the devive manager the code error is 10. The model of the computer is GM5066B and the serial no. GSG7211000075. Same problem on a Compaq Presario SR5213 with...
Things to check
1. See if the drive is identified properly in BIOS, if it is not, reseat all cables and try agian.
2. Can you boot to the drive using a bootable CD (XP CD or such) If the drive functions outside Windows, then it is a software issue. If it doesn't boot to bootable media, then you most likely have a hardware issue.
If you can boot to the CD, then try booting to the safe mode, removing the drive from device manager then remove the upper/lower filters in the registry then reboot in to the normal mode.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Jan 25, 2009 | Compaq Presario 5000 PC Desktop
Cd/rom not working
rub1 hello,
It seems like a hardware problem with your cd/DVD drive.
I suggest trying to use Windows Update, perhaps there is a driver conflict.
Try to update the drivers on everything, and see if this works.
If not, try rolling back the driver for the drive.
If none of that works, enter the BIOS by pressing F1 when your computer starts (before Windows gets on).
There, check if DVD/CD drive is Enabled or Disabled.
If it is disabled, it might indicate a hardware failure. Then, if warranty is still applicable, I would suggest sending your laptop to a service provider near you.
Sep 03, 2008 | Lenovo 3000 C200 Notebook
TEAC DV W28ECT ATA DEVICE CODE 10
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Aug 24, 2008 | Teac CD-Rewritable W28E CD-RW Burner
DVD/CD Drive is not responding. Model Inspiron 1420
right click my computer, select manage, then on the left side find device manager.
in the device manager find your cd drive and see if it has a error code
if there is a error code then here is a fix i made long time go for few error codes
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
Jul 19, 2008 | Dell Inspiron Notebook
I bought this computer on 22/3/08 and this is the second time I have had this problem. My CD/DVD Drive has suddenly stopped working.In the devive manager the code error is 10. The model of the computer is...
Kind Regards,
Stef
Apr 17, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Compaq Deskpro EP PIII-650MHz/ 128MB/ 10GB/CDROM/ FDD/ ENET/ Keyboard/ Mouse/ WIN98COA/ No OS - (CODEEPPI1210) PC Desktop Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
