PC does not see full size of hard disk drive
I have a new 250g Hard disk drive coz my old one went faulty, however when i reload windows Xp it says I only have 131G why is thi?
  • Ashforim Apr 17, 2008
    I don't think I have in this case as I'm running the PC from the CD to start on a fresh hard drive, its the windows xp as it loads to the machine that reports 131gb.
    I have also tried during this start from fresh process to partition the hard drive, however I do it windows reports 131 gb.
    Any other thoughts
    Problem Solver:
  • 15 Answers
You could have partitioned your hd by accident giving you only 131gb, or and this one is just a crazy guess windows could have taken up that much space, although dont quote me on it!
Posted on Apr 17, 2008
Not seeing new hard disk or reading XP cd-rom
It can use any 31/2" IDE hard drive. 30 Gb should be OK
If the BIOS cannot detect the hard drive or the CD drive then the drives maybe faulty or the disk controller in the computer is faulty.
Apr 29, 2012 | IBM ThinkPad A30 Notebook
What drivers are need for clean windows xp install on sony vaio pcg-k37?
This model Sony came installed with a 80Gb hard disk and a 40 Gb
Do a clean Windows install on this old hard drive -
Boot up with the Windows installation CD
install Windows on the hard drive
Delete the existing Windows partition
Create a new partition
Format the new partition (full format not Quick format)
Continue installing Windows.
Mar 24, 2012 | Sony PCGK37 Notebook
I cont intstal win xp in my toshiba U200-148 laptop
you can use another installer coz maybe your installer have some scratches
May 22, 2011 | Computers & Internet
I HAVE FORMATTED MY PC AND RELOADED THE WINDOWS XP, AFTER LOADING THE HARDWARE DRIVER, SOMETHING WENT UNUSUAL AND SYSTEM SHUTSDOWN EACHDOWN WHEN AFTER BOOTING WINDOWS XP. THEN I RELOADED WINDOWS XP AGAIN....
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 24, 2011 | EliteGroup ECS P4M800-M Socket...
HP Pavillion m7750n has already had the hard drive replaced almost two years ago. The computer will be four in January. It stopped working about five months ago and I finally decided I had enough time to...
Either the disk is faulty or the the boot block is corrupted. If you have the operating system CD, you can try to reload it. Doing so will wipe out anything you have on the drive. If it reloads, you will be back in business. It the disk is faulty, the OS will not load.
You may want to take this computer into the Big Box store and have it evaluated before youtry to do this repair.
Thanks for your interest in FixYa.com
Nov 23, 2010 | HP Pavilion m7750n PC Desktop
Western Digital Reset / Set Hard Disk Size ?
hit F1 when you bootup dont let windows come on . Go in you Biso to set you new hard drive.dont forget to F10 to save changes...Good Luck
Aug 15, 2009 | Western Digital 500GB My Book World...
Complaining about hard disk not inserted
The problem is either the BIOS is not detecting the hard drive or the hard drive is faulty or the disk controller is faulty. Check the BIOS setting to see if it has detected the hard disk, and if there is a hard drive diags run it to test the hard drive. Try reseating the hard drive and if it doesn't work, remove the hard drive and connect it to an USB hard drive adapter. Plug this adapter into a working computer's USB port and if this computer detects this as an external hard drive and you can view and open the various folders and files, then the hard drive is OK. If you haven't any files or folders in the hard drive, then format the hard drive from this computer to test this hard drive. If the hard drive is OK then the fault is probably the disk controller. If the hard drive is faulty, then you need a new hard drive in your computer.
Jun 10, 2009 | HP Compaq nx9420 Notebook
Hard drive not seen in dell latitude d600 after upgrade to vista
Your hard drive may need reseating.
If it still gives error hard disk not found then you have a faulty hard drive.
You need a new hard drive and then install Windows Vista
Mar 23, 2009 | Dell Lattitude D600 Notebook
Need to reload windows xp on Emachines PC
Yes all you have to do is.........
Turn off the Computer
Turn back on and Press F11 repeatedly when the message "Press F11 to start recovery" is displayed.
The recovery will load and display a menu of options:
Full System Restore (with Backup): This options will move all Hard Disk contents to the "c:\My Backup" directory and install a new copy of Windows. This option preserves your existing data files, however all applications and settings will need to be reinstalled. This option requires 4GB of free Hard Disk space for the new OS.
Alway suggest backing up your data before you do any recovery
Mar 19, 2009 | E-Machines eMachines Desktop PC
Laptop not booting
Was this a reload of XP, if so what was the cause for the reload? This sounds like the hard drive may have failed. I've had them where the reload seems to take , then it either won't boot or will have issues running properly. This is caused by one or two bad sectors in the drive. The drive has many sectors, depending on the size. First try reinstalling XP, if it has any problems during or after the install, then it's the hard drive. If this wasn't a reload or it's a new hard drive let me know and we'll take a different approach.
Jun 25, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
